SQL Server利用XML找字符串相同部分
DECLARE @a NVARCHAR(100)= '01,02,04,05,07'; DECLARE @b NVARCHAR(100)= '01,03,04,05,06'; WITH a1 AS ( SELECT CONVERT(XML, '' + REPLACE(@a, ',', '') + '') cxml ), a AS ( SELECT v.value('.', 'varchar(100)') cv FROM a1 CROSS APPLY cxml.nodes('/root/v') AS C ( v ) ), b1 AS ( SELECT CONVERT(XML, '' + REPLACE(@b, ',', '') + '') cxml ), b AS ( SELECT v.value('.', 'varchar(100)') cv FROM b1 CROSS APPLY cxml.nodes('/root/v') AS C ( v ) ), x1 AS ( SELECT 1 AS z , a.cv FROM a JOIN b ON a.cv = b.cv ), x0 AS ( SELECT z , ( SELECT cv + ',' FROM x1 WHERE z = t1.z ORDER BY z FOR XML PATH('') ) AS l FROM x1 t1 GROUP BY z ) SELECT LEFT(l, LEN(l) - 1) AS vs FROM x0;
vs
01,04,05
(1 行受影响)
