当前位置:首页 > 芯闻号 > 充电吧
[导读]Sub Query()     Dim Conn As Object, Rst As Object     Dim strConn As String, strSQL As String     Di
Sub Query()
    Dim i As Integer, PathStr As String
    Set Conn = CreateObject("ADODB.Connection")
    Set Rst = CreateObject("ADODB.Recordset")
    PathStr = ThisWorkbook.FullName   '设置工作簿的完整路径和名称
    Select Case Application.Version * 1    '设置连接字符串,根据版本创建连接
    Case Is = 12
        strConn = "Provider=Microsoft.ACE.OLEDB.12.0;Data Source=" & PathStr & ";Extended Properties=""Excel 12.0;HDR=YES"";"""
    End Select
    '设置SQL查询语句
    strSQL = "SELECT DISTINCT 发站 FROM [LMSData2016.12$]"
    Conn.Open strConn    '打开数据库链接
    Set Rst = Conn.Execute(strSQL)    '执行查询,并将结果输出到记录集对象
    With Sheet1
        .Cells.Clear
        For i = 0 To Rst.Fields.Count - 1    '填写标题
            .Cells(1, i + 1) = Rst.Fields(i).Name
        Next i
        .Range("A2").CopyFromRecordset Rst
        .Cells.EntireColumn.AutoFit  '自动调整列宽
    End With
    Rst.Close    '关闭数据库连接
    Conn.Close
    Set Conn = Nothing
    Set Rst = Nothing
End Sub
