如何删除发布与复制订阅数据库 'distribuion' 的方法
之前因为从VFP数据库中把数据导入到SQL SERVER2000中,用DTS做了发布与复制数据库'distribution' ,现在要把它删除,当在企业管理器中执行删除时,提示下面的错误:
Error 3724: cannot drop the database 'distribution' because it is being used for replication.
解决方法:
一、首先要备份 master 数据库,在查询分析器选择 master 数据库下操作:
sp_configure 'allow updates',1
reconfigure with override
go
update master..sysdatabases set category = 0 where name='distribution'
delete the distribution database
执行了上面的命令,就可以在企业管理器中删除'distribution'数据库了。
二、方法讨论:
1、如果你只执行这条命令:update master..sysdatabases set category = 0 where name='distribution'
会出现错误:Ad hoc updates to system catalogs are not enabled. The system administrator
must reconfigure SQL Server to allow this.
所以你在必须先执行:
go
这条命令允许更新,上面的错误才能解决。
2、也可以移除,自己翻译一下 ^_^: Make sure that you did not enable this database for replication by using the sp_helpreplicationdboption system stored procedure. Do not enable the database for replication. If it is enabled for replication, run the sp_removedbreplication stored procedure to disable replication.
IMPORTANT: Running sp_removedbreplication on a database removes all replication objects from the database. Therefore, all publications and subscriptions in the database are removed. Only members of the sysadmin fixed server role can run the sp_removedbreplication stored procedure. For more information about the sp_removedbreplication stored procedure, see the "sp_removedbreplication, Transact-SQL Reference" topic in SQL Server Books Online.
To run the sp_removedbreplication stored procedure, use the following code in which you replace dbname with the name of your database:
执行命令: sp_removedbreplication 'distribution'
参考英文资料:
http://www.ureader.com/message/145316.aspx
http://support.default.aspx?scid=kb;en-us;326352
