当前位置:首页 > 芯闻号 > 充电吧
[导读]利用 51 单片机构成计数器,计数的上限,做的大一些,也不难,几千几万都可以。下面的电路,小了一点,是个两路两位的计数器。用来记录乒乓球比赛,还算可以,用于篮球比赛,分数超过 99,这个电路就不够用了
用来记录乒乓球比赛,还算可以,用于篮球比赛,分数超过 99,这个电路就不够用了。
电路图中,用的是共阳数码管;还设置了六个按键,用途,都已经标出。
用 C 语言编写驱动程序,是比较简单的,全部代码如下:
#include
unsigned char  n1, n2;
void delay(unsigned int i)   //1ms延时程序
    unsigned char  j;
    while(i--)   for(j = 0; j < 115; j++);
void disp(void)
    unsigned char code SEG[] = {
      0xc0, 0xf9, 0xa4, 0xb0, 0x99, //0-4
      0x92, 0x82, 0xf8, 0x80, 0x90};//5-9
    P0 = SEG[n1 / 10]; P1 = 1; delay(2); P1 = 0;
    P0 = SEG[n1 % 10]; P1 = 2; delay(2); P1 = 0;
    P0 = SEG[n2 / 10]; P1 = 4; delay(2); P1 = 0;
    P0 = SEG[n2 % 10]; P1 = 8; delay(2); P1 = 0;
void main(void)
    unsigned char k, t;
    n1 = n2 = 0;
    while(1) {
      disp();
      if (~(P2 | 0xc0)) {
        disp();
        if (~(P2 | 0xc0)) {
          k = ~(P2 | 0xc0);
          while (~(P2 | 0xc0))  disp();
          if       (k == 1)  {n1++; if (n1 == 100) n1 = 0;}
          else  if (k == 2)  {n1--; if (n1 == -1) n1 = 99;}
          else  if (k == 4)  {n2++; if (n2 == 100) n2 = 0;}
          else  if (k == 8)  {n2--; if (n1 == -1) n2 = 99;}
          else  if (k == 16) {n1 = n2 = 0;}
          else  if (k == 32) {t = n1; n1 = n2; n2 = t;}
是不是很简单?
用汇编语言来编程,就显得长多了。
和上述 C 语言功能相同的汇编语言程序,全部代码如下:
    ORG   0000H
    JMP   MAIN
    ORG   0030H
MAIN:
    CALL  DISP
    MOV   A, P2
    CJNE  A, #0FFH, KEY
    CLR   00H
    JMP   MAIN
KEY:
    JNB   00H, A_ADD1
    JMP   MAIN
A_ADD1:
    SETB  00H
    JB    P2.0, A_SUB1
    MOV   A, R0
    ADD   A, #01H
    DA    A
    MOV   R0, A
    JMP   MAIN
A_SUB1:
    JB    P2.1, B_ADD1
    MOV   A, R0
    ADD   A, #99H
    DA    A
    MOV   R0, A
    JMP   MAIN
B_ADD1:
    JB    P2.2, B_SUB1
    MOV   A, R1
    ADD   A, #01H
    DA    A
    MOV   R1, A
    JMP   MAIN
B_SUB1:
    JB    P2.3, CLR_0
    MOV   A, R1
    ADD   A, #99H
    DA    A
    MOV   R1, A
    JMP   MAIN
CLR_0:
    JB    P2.4, EXCH
    MOV   R0, #00H
    MOV   R1, #00H
    JMP   MAIN
EXCH:
    JB    P2.5, END_K
    MOV   A, R0
    XCH   A, R1
    MOV   R0, A
    JMP   MAIN
END_K:
    CLR   00H
    JMP   MAIN
DISP:
    MOV   DPTR, #BG
    MOV   A, R0
    SWAP  A
    ANL   A, #0FH
    MOVC  A, @A + DPTR
    MOV   P0, A
    SETB  P1.0
    CALL  DELAY
    CLR   P1.0
    MOV   A, R0
    ANL   A, #0FH
    MOVC  A, @A + DPTR
    MOV   P0, A
    SETB  P1.1
    CALL  DELAY
    CLR   P1.1
    MOV   A, R1
    SWAP  A
    ANL   A, #0FH
    MOVC  A, @A + DPTR
    MOV   P0, A
    SETB  P1.2
    CALL  DELAY
    CLR   P1.2
    MOV   A, R1
    ANL   A, #0FH
    MOVC  A, @A + DPTR
    MOV   P0, A
    SETB  P1.3
    CALL  DELAY
    CLR   P1.3
RET
DELAY:
    DJNZ  R7, $
    DJNZ  R7, $
    DJNZ  R7, $
    DJNZ  R7, $
RET
BG:
    DB  0C0H,0F9H,0A4H,0B0H, 99H
    DB   92H, 82H,0F8H, 80H, 90H
END
汇编语言的程序,看起来,比 C 语言的程序,长了不少,但是,编译后生成的机器码,却少于 C 程序。
谁来看一看,编译后生成的机器码占用 ROM 空间,相差了多少?
其实,这个汇编语言的程序,编程的思路,并不是很好的,程序,还是可以优化的。
