当前位置:首页 > 芯闻号 > 充电吧
[导读]JAVA中所有类的祖先类都是object类,object类有一个很暴力的方法 getClass 例子,通过他得到子类的类名:getSimpleNamepublic class Test11A
public class Test11A     {
     public void   check(Obj j) {
         System.out.println(j.getClass().getSimpleName());
    public static void main(String[] args) {
        // TODO 自动生成的方法存根
        Test11A test11a = new Test11A();
        Obj obj = new Sub1();
        Obj obj2 = new Sub2();
        test11a.check(obj);
        test11a.check(obj2);
输出:
Sub1
Sub2
getName:
com.java.Obj.Sub1
com.java.Obj.Sub2
getDeclaredFields:获得成员变量数组
public class Sub1 extends Obj {
    private  int x;
    private  int y;
    public String string;
    public  void Test()
        System.out.println("Sub1 Test");
         System.out.println(j.getClass().getClassLoader());
     public void   check2(Obj j) {
            // 取得本类的全部属性
         Class mclass =null;
         mclass= j.getClass();
        Field[] fields= mclass.getDeclaredFields();
        for (int i = 0; i < fields.length; i++) {
            Field field = fields[i];
            Class  curClass=field.getType();
            System.out.println(field.getModifiers()+","+curClass.getTypeName()+","+field.getName());
        // TODO 自动生成的方法存根
        test11a.check2(obj);
        test11a.check2(obj2);
输出:
2,int,x
2,int,y
1,java.lang.String,string
访问修饰符是字符串,用java函数转换:
            // 取得本类的全部属性
         Class mclass =null;
            System.out.println(Modifier.toString((field.getModifiers()))+","+curClass.getTypeName()+","+field.getName());
输出:
private,int,x
private,int,y
public,java.lang.String,string
        // 取得本类的全部属性
        Class mclass = null;
        mclass = j.getClass();
        Field[] fields = mclass.getDeclaredFields();
            Class curClass = field.getType();
            System.out.println(
                    Modifier.toString((field.getModifiers())) + "," + curClass.getTypeName() + "," + field.getName());
public void check3(Obj j) {
    // 取得本类的全部方法
    Method[] marray = mclass.getDeclaredMethods();
    for (int i = 0; i < marray.length; i++) {
        Method field = marray[i];
         java.lang.reflect.Parameter[] parameters= field.getParameters();
         for (int k = 0; k < parameters.length; k++) {
            java.lang.reflect.Parameter parameter = parameters[k];
            System.out.println(parameter.getType().getName());
         System.out.println(","+Modifier.toString(field.getModifiers()) + " " + field.getReturnType().getTypeName() + ":"
                + field.getName());
    public void check4(Obj j) {
        // 根据字符串调用对象方法
        try {
            Method method = mclass.getDeclaredMethod("Test2",String.class,int.class);
            method.invoke(j,"hi",555);
        } catch (NoSuchMethodException | SecurityException | IllegalAccessException | IllegalArgumentException
                | InvocationTargetException e) {
            // TODO 自动生成的 catch 块
            e.printStackTrace();
 void  check5( ) throws InstantiationException, IllegalAccessException
         //根据类名生成对象实例
         try {
            Class mClass = Class.forName("com.java.Obj.Sub1");
                try{
                   Object obj =mClass.newInstance();
                    Method  fucMethod= mClass.getMethod("Test2", String.class,int.class);
                    fucMethod.invoke(obj, "hello ",123);
                }catch(Exception e){
        } catch (ClassNotFoundException e) {
