当前位置:首页 > 芯闻号 > 充电吧
[导读]int.S: ;************************************************************************ ;*
int.S:
;* FUNCTION
;* INT_Initialize
;* DESCRIPTION
;* This function sets up the global system stack variable and
;* transfers control to the target independent initialization
;* function INC_Initialize. Responsibilities of this function
;* include the following:
;* - Setup necessary processor/system control registers
;* - Initialize the vector table
;* - Setup the system stack pointers
;* - Setup the timer interrupt
;* - Calculate the timer HISR stack and priority
;* - Calculate the first available memory address
;* - Transfer control to INC_Initialize to initialize all of
;* the system components.
;* Major Revision:
;* M. Kyle Craig, Accelerated Technology, Inc.
;* CALLED BY
;* Nothing. This function is the ENTRY point for Nucleus PLUS.
;* CALLS
;* INC_Initialize                      Common initialization
;* INPUTS
;* None
;* OUTPUTS
;* None
;* HISTORY
;* NAME DATE                    REMARKS
;* W. Lamie        08-27-1994      Created initial version 1.0
;* D. Lamie        08-27-1994      Verified version 1.0
;VOID    INT_Initialize(void)
    .def    _c_int00
_c_int00
    .def  _INT_Initialize
_INT_Initialize:
    ; Insure that the processor is in supervisor mode.        //设置了arm的svc模式
    MRS     r0,CPSR ; Pickup current CPSR
    BIC     r0,r0,#MODE_MASK ; Clear the mode bits
    ORR     r0,r0,#SUP_MODE ; Set the supervisor mode bits
    ORR     r0,r0,#LOCKOUT ; Insure IRQ/FIQ interrupts are        //关闭中断
                                        ; locked out
    MSR     CPSR,r0 ; Setup the new CPSR
    ; Clear the un-initialized global and static C data areas.
    LDR     r0,BSS_Start ; Pickup the start of the BSS area
    MOV r2,#0 ; Clear value in r2
    LDR     r1,BSS_End ; Pickup the end of the BSS area
INT_BSS_Clear_Loop
    STR r2,[r0],#4 ; Clear a word        //初始化Bss段
INT_BSS_Clear_Check
    CMP r0,r1 ; Are the start and end equal?
    BNE     INT_BSS_Clear_Loop ; If so, continue with BSS clear
    ; Perform auto-initialization. if cinit is -1, then there is none.
    LDR     r0, c_cinit
    CMN     r0, #1
    BLNE    _auto_init
    ; Turn-on the I-Cache for the TI 925T Processor        //开启I-Cache
    MRC     p15,#0,r1,C1,C0,#0 ; Read the control register.
    ORR     r1,r1,#0x1000 ; Set the I bit to enable Instruction Cache
    NOP
    MCR     p15,#0,r1,C1,C0,#0 ; Write the control register.
; Setup the vectors loaded flag to indicate to other routines in the
; system whether or not all of the default vectors have been loaded.
; If INT_Loaded_Flag is 1, all of the default vectors have been loaded.
; Otherwise, if INT_Loaded_Flag is 0, registering an LISR cause the
; default vector to be loaded. In the ARM60 this variable is always
; set to 1. All vectors must be setup by this function.
; INT_Loaded_Flag = 0;
    MOV r0,#1 ; All vectors are assumed loaded
    LDR     r1,Loaded_Flag ; Build address of loaded flag
    STR r0,[r1,#0] ; Initialize loaded flag
; Initialize the system stack pointers. This is done after the BSS is
; clear because the TCD_System_Stack pointer is a BSS   It is
; assumed that available memory starts immediately after the end of the
; BSS section.        //建立sys stack
    LDR     r10,System_Stk_Limit ; Pickup the system stack limit (bottom of system stack)
    LDR     r3,System_Limit ; Pickup sys stack limit addr
    STR r10,[r3, #0] ; Save stack limit
    LDR     sp,System_Stack_SP ; Set-up the system stack pointer
    LDR     r3,System_Stack ; Pickup system stack address
    STR sp,[r3, #0] ; Save stack pointer
    ORR     r0,r0,#IRQ_MODE ; Set the IRQ mode bits
    MSR     CPSR,r0 ; Move to IRQ mode
    LDR     sp,IRQ_Stack_SP ; Setup IRQ stack pointer
    ORR     r0,r0,#FIQ_MODE ; Set the FIQ mode bits
    MSR     CPSR,r0 ; Move to the FIQ mode
    LDR     sp,FIQ_Stack_SP ; Setup FIQ stack pointer
    BIC     r0,r0,#MODE_MASK ; Clear mode bits
    MSR     CPSR,r0 ; All interrupt stacks are setup,
                                            ; return to supervisor mode
; Define the global data structures that need to be initialized by this        //设置中断
; routine. These structures are used to define the system timer
; management HISR.
; TMD_HISR_Stack_Ptr = (VOID *) r2;
; TMD_HISR_Stack_Size = TIMER_SIZE;
; TMD_HISR_Priority = TIMER_PRIORITY;
    LDR     r2,HISR_Stack_Mem ; Get HISR stack memory address
    LDR     r3,HISR_Stack_Ptr ; Pickup variable's address
    STR     r2,[r3, #0]                     ; Setup timer HISR stack pointer
    MOV     r1,#HISR_STACK_SIZE             ; Pickup the timer HISR stack size
    LDR     r3,HISR_Stack_Size              ; Pickup variable's address
    STR r1,[r3, #0] ; Setup timer HISR stack size
    MOV r1,#HISR_PRIORITY ; Pickup timer HISR priority (0-2)
    LDR     r3,HISR_Priority ; Pickup variable's address
    STR     r1,[r3, #0]                     ; Setup timer HISR priority
; Make a call to begin all board specific initialization.        //初始化时钟
; Begin with Initializing the Vector table and replacing
; default interrupts with Plus IRQs.  Then setup the timer
; and begin the system clock.
    .if $$isdefed("NU_ROM_SUPPORT")
    BL      _INT_Timer_Initialize           ; Initialize the timer
    .else
    BL      INT_Install_Vector_Table        ; Install the vector table
    .endif
; Call INC_Initialize with a pointer to the first available memory
; address after the compiler's global data. This memory may be used
; by the application.
; INC_Initialize(first_available_memory);
    LDR     r0,First_Avail_Mem ; Get address of first available memory
    B       _INC_Initialize ; to high-level initialization        //最后跳转到_INC_Initialize,找不到函数在哪
   。。。。。。    。。。。。。 初始化组件由三个部分组成,硬件在reset后首先进入INT_initialize(),进行板级的相关初始化,首先设置SVC mode,关中断,然后将内核从rom中拷贝至ram中,建立bss段,依次建立sys stack, irq stack和fiq stack,最后初始化timer,建立timer HISR的栈空间,看了一下2410平台的代码,一个tick大概是15.8ms,完成板级的初始化后就进入了INC_initialize。
inc.c:
/* Copyright Mentor Graphics Corporation 2002 */
/* All Rights Reserved. */
/* THIS WORK CONTAINS TRADE SECRET AND PROPRIETARY INFORMATION WHICH IS */
/* THE PROPERTY OF MENTOR GRAPHICS CORPORATION OR ITS LICENSORS AND IS */
/* SUBJECT TO LICENSE TERMS. */
/* FILE NAME                                               VERSION */
/* inc.c                                          Nucleus PLUS 1.14 */
/* COMPONENT */
/* IN - Initialization */
/* DESCRIPTION */
/* This file contains initialization and setup routines associated */
/* with the initialization component. */
/* DATA STRUCTURES */
/* None */
/* FUNCTIONS */
/* INC_Initialize                      Common system initialization */
/* DEPENDENCIES */
/* in_extr.h                           Initialization functions */
/* er_extr.h Error handling function */
/* hi_extr.h History functions */
/* tc_extr.h                           Thread Control functions */
/* mb_extr.h                           Mailbox functions */
/* qu_extr.h                           Queue functions */
/* pi_extr.h                           Pipe functions */
/* sm_extr.h                           Semaphore functions */
/* ev_extr.h                           Event group functions */
/* pm_extr.h                           Partition memory functions */
/* dm_extr.h                           Dynamic memory functions */
/* tm_extr.h                           Timer functions */
/* io_extr.h                           I/O Driver functions */
/* HISTORY */
/* DATE REMARKS */
/* 03-01-1993      Created initial version 1.0 */
/* 04-19-1993      Verified version 1.0 */
/* 03-01-1994      Replaced void with VOID, */
/* resulting in version 1.1 */
/* 03-18-1994      Verified version 1.1 */
/* 04-17-1996      updated to version 1.2 */
/* 03-20-1998      Moved the INC_Initialize_State */
/* define values into their own */
/* in_defs.h include file as part */
/* of SPR455. This creates */
/* version 1.2a. */
/* 03-24-1998      Released version 1.3. */
/* 03-26-1999      Released 1.11m (new release */
/* numbering scheme) */
/* 04-17-2002      Released version 1.13m */
/* 11-07-2002      Released version 1.14 */
#define         NU_SOURCE_FILE
#include "in_defs.h" /* Initialization defines */
#include "in_extr.h" /* Initialization functions */
#include "hi_extr.h" /* History functions */
#include "er_extr.h" /* Error handling function */
#include "tc_extr.h" /* Thread Control functions */
#include "mb_extr.h" /* Mailbox functions */
#include "qu_extr.h" /* Queue functions */
#include "pi_extr.h" /* Pipe functions */
#include "sm_extr.h" /* Semaphore functions */
#include "ev_extr.h" /* Event group functions */
#include "pm_extr.h" /* Partition memory functions*/
#include "dm_extr.h" /* Dynamic memory functions */
#include "tm_extr.h" /* Timer functions */
#include "io_extr.h" /* I/O Driver functions */
/* Define global variable that contains the state of initialization. This
   flag is for information use only. */
INT INC_Initialize_State;
/* Define external functions that access the release and license
   information. */
CHAR *RLC_Release_Information(VOID);
CHAR *LIC_License_Information(VOID);
#if defined(NU_MODULE_SUPPORT) && (NU_MODULE_SUPPORT > 0)
/* Prototypes for Module Initialization funcitons */
STATUS MRC_Initialize(VOID);
STATUS MSC_Initialize(VOID);
#endif
/* FUNCTION */
/* INC_Initialize */
/* DESCRIPTION */
/* This function is the main initialization function of the system. */
/* All components are initialized by this function. After system */
/* initialization is complete, the Application_Initialize routine */
/* is called. After all initialization is complete, this function */
/* calls TCT_Schedule to start scheduling tasks. */
/* CALLED BY */
/* INT_Initialize                      Target dependent initialize */
/* CALLS */
/* Application_Initialize              Application initialize */
/* RLC_Release_Information             Release information */
/* LIC_License_Information             License information */
/* ERI_Initialize Error handling initialize */
/* HII_Initialize History initialization */
/* TCI_Initialize                      Thread control initialize */
/* MBI_Initialize                      Mailbox initialize */
/* QUI_Initialize                      Queue initialize */
/* PII_Initialize                      Pipe initialize */
/* SMI_Initialize                      Semaphore initialize */
/* EVI_Initialize                      Event flag initialize */
/* PMI_Initialize                      Partition memory initialize */
/* DMI_Initialize                      Dynamic memory initialize */
/* TMI_Initialize                      Timer initialize */
/* IOI_Initialize                      I/O Driver initialize */
/* MRC_Initialize                      Memory Region initialize */
/* MSC_Initialize                      Module Support initialize */
/* TCT_Schedule                        Thread scheduling loop */
/* INPUTS */
/* first_available_memory              Pointer to available memory */
/* OUTPUTS */
/* None */
/* HISTORY */
/* DATE REMARKS */
VOID  INC_Initialize(VOID *first_available_memory)
    /* Indicate that initialization is starting. */
    INC_Initialize_State = INC_START_INITIALIZE;
    /* Call release information function. */
    RLC_Release_Information();
    /* Call license information function. */
    LIC_License_Information();
    /* Initialize the Error handling (ER) component. */
    ERI_Initialize();
    /* Initialize the History (HI) component. */
    HII_Initialize();
    MRC_Initialize(); /* Initialize Memory Region component */
    MSC_Initialize(); /* Initialize Module Support component */
#endif
    /* Initialize the Thread Control (TC) component. */
    TCI_Initialize();
    /* Initialize the Mailbox (MB) component. */
    MBI_Initialize();
    /* Initialize the Queue (QU) component. */
    QUI_Initialize();
    /* Initialize the Pipe (PI) component. */
    PII_Initialize();
    /* Initialize the Semaphore (SM) component. */
    SMI_Initialize();
    /* Initialize the Event Group (EV) component. */
    EVI_Initialize();
    /* Initialize the Partition memory (PM) component. */
    PMI_Initialize();
    /* Initialize the Dynamic memory (DM) component. */
    DMI_Initialize();
    /* Initialize the Timer (TM) component. */
    TMI_Initialize();
    /* Initialize the I/O Driver (IO) component. */
    IOI_Initialize();
    /* Invoke the application-supplied initialization function. */
    Application_Initialize(first_available_memory);                                            //应用程序初始化
    /* Indicate that initialization is finished. */
    INC_Initialize_State = INC_END_INITIALIZE;
    /* Start scheduling threads of execution. */
    TCT_Schedule();
} 到这里找不到函数了。。。
csc.c:包含nucleus plus系统中使用的连接表处理工具,采用双向循环链表(doubley-linked circulat lists)
dmc.c:包含动态内存管理组件的核心事务
dmce.c:包含动态内存管理组件中的函数错误检查例程,可以关闭?
dmd.c:包含动态内存管理组件中的全局数据结构
dmf.c:包含获取管理动态内存管理组件的事实的例程
dmi.c:包含动态内存管理组件的初始化例程
dms.c:包含动态内存管理组件的补充例程
erc.c:包含错误管理组件的核心事务
erd.c:包含错误管理组件的官居数据结构
eri.c:包含错误管理组件初始化例程
evc.c:包含事件组管理组件核心事务
evce.c:包含事件组错误检查
evd.c:事件组全局数据结构
evf.c
evi.c
hic.c:包含历史管理组件的核心事务
hid.c
hii.c
inc.c
int.s
ioc.c:I/O驱动管理核心事务
ioce.c
iod.c
iof.c
ioi.c
lic.c:license informations组件核心事务
lid.c
mbc.c:邮箱管理组件核心事务
mbce.c
mbd.c
mbf.c
mbi.c
mbs.c
mbse.c
pic.c:管道管理核心事务
pice.c
pid.c
pif.c
pii.c
pis.c
pise.c
pmc.c:内存管理划分(partition)核心事务
pmce.c
pmd.c
pmf.c
pmi.c
quc.c:队列管理核心事务
quce.c
qud.c
quf.c
qui.c
qus.c
quse.c
rlc.c:版本信息(Release Information)核心事务
rld.c
sdc.c:包含串行驱动特定功能
smc.c:信号量管理核心事务
smce.c
smd.c
smd.c
smf.c
smi.c
sms.c
smse.c
tcc.c:进程控制
tcce.c
tcd.c
tcf.c
tci.c
tcs.c
tcse.c
tct.s
tmc.c:此函数负责提供初始化的任务定时器,此程序必须在svc/usr模式下内核切换成svc模式运行。
tmd.c
tmf.c
tmi.c
tms.c
tmse.c
tmt.s
文件命名前2个字母是组件的缩写,后面的字母是不同的文件。
d包含了相关全局变量,i是初始化部分,f是组件管理的对象的信息,c是核心函数,ce是错误处理,se是补充。
