SQL查询死锁
Select '进程ID' = Str( A.Spid, 4 ), '进程ID状态' = Convert( varChar(100), A.Status ), '阻塞进程的进程ID' = Str( A.Blocked, 2 ), '工作站名称' = Convert( varChar(100), A.Hostname ), '执行命令的用户' = Convert( varChar(100), A.loginame ), '数据库名' = Convert( varChar(100), Db_Name(A.Dbid ) ), '应用程序名' = Convert( varChar(100), A.Program_Name ), '正在执行的命令' = Convert( varchar(100), A.Cmd ), '累计CPU时间' = Str( A.Cpu, 7 ), 'IO' = Str( A.Physical_Io, 7 ), '登录名' = A.Loginame, '登录时间' = A.login_time, '执行语句'=B.Text From Master..Sysprocesses A Cross Apply Sys.Dm_Exec_Sql_Text(A.Sql_Handle) B Where Spid In ( Select top 10 spid From Master..Sysprocesses order by physical_io DESC) order by login_time
--有查出来几个表是没有主键,也没有聚集索引。 SELECT OBJECT_NAME(i.[object_id]) AS [Table Name] , i.name FROM sys.indexes AS i INNER JOIN sys.objects AS o ON i.[object_id] = o.[object_id] WHERE i.index_id NOT IN ( SELECT ddius.index_id FROM sys.dm_db_index_usage_stats AS ddius WHERE ddius.[object_id] = i.[object_id] AND i.index_id = ddius.index_id AND database_id = DB_ID() ) AND o.[type] = 'U' ORDER BY OBJECT_NAME(i.[object_id]) ASC;
--有查到缺失索引的情况。 SELECT user_seeks * avg_total_user_cost * ( avg_user_impact * 0.01 ) AS [index_advantage] , dbmigs.last_user_seek , dbmid.[statement] AS [Database.Schema.Table] , dbmid.equality_columns , dbmid.inequality_columns , dbmid.included_columns , dbmigs.unique_compiles , dbmigs.user_seeks , dbmigs.avg_total_user_cost , dbmigs.avg_user_impact FROM sys.dm_db_missing_index_group_stats AS dbmigs WITH ( NOLOCK ) INNER JOIN sys.dm_db_missing_index_groups AS dbmig WITH ( NOLOCK ) ON dbmigs.group_handle = dbmig.index_group_handle INNER JOIN sys.dm_db_missing_index_details AS dbmid WITH ( NOLOCK ) ON dbmig.index_handle = dbmid.index_handle WHERE dbmid.[database_id] = DB_ID() ORDER BY index_advantage DESC;
--有查到几个索引不合理,写的很多,查询用到的很少 SELECT OBJECT_NAME(ddius.[object_id]) AS [Table Name] , i.name AS [Index Name] , i.index_id , user_updates AS [Total Writes] , user_seeks + user_scans + user_lookups AS [Total Reads] , user_updates - ( user_seeks + user_scans + user_lookups ) AS [Difference] FROM sys.dm_db_index_usage_stats AS ddius WITH ( NOLOCK ) INNER JOIN sys.indexes AS i WITH ( NOLOCK ) ON ddius.[object_id] = i.[object_id] AND i.index_id = ddius.index_id WHERE OBJECTPROPERTY(ddius.[object_id], 'IsUserTable') = 1 AND ddius.database_id = DB_ID() AND user_updates > ( user_seeks + user_scans + user_lookups ) AND i.index_id > 1 ORDER BY [Difference] DESC , [Total Writes] DESC , [Total Reads] ASC;
--有查到缺失索引的情况。 SELECT '[' + DB_NAME() + '].[' + OBJECT_SCHEMA_NAME(ddips.[object_id], DB_ID()) + '].[' + OBJECT_NAME(ddips.[object_id], DB_ID()) + ']' AS [statement] , i.[name] AS [index_name] , ddips.[index_type_desc] , ddips.[partition_number] , ddips.[alloc_unit_type_desc] , ddips.[index_depth] , ddips.[index_level] , CAST(ddips.[avg_fragmentation_in_percent] AS SMALLINT) AS [avg_frag_%] , CAST(ddips.[avg_fragment_size_in_pages] AS SMALLINT) AS [avg_frag_size_in_pages] , ddips.[fragment_count] , ddips.[page_count] FROM sys.dm_db_index_physical_stats(DB_ID(), NULL, NULL, NULL, 'limited') ddips INNER JOIN sys.[indexes] i ON ddips.[object_id] = i.[object_id] AND ddips.[index_id] = i.[index_id] WHERE ddips.[avg_fragmentation_in_percent] > 15 AND ddips.[page_count] > 500 ORDER BY ddips.[avg_fragmentation_in_percent] , OBJECT_NAME(ddips.[object_id], DB_ID()) , i.[name]
