当前位置:首页 > 芯闻号 > 充电吧
[导读] CREATE PROCEDURE YourProcedure     AS BEGIN     SET NOCOUNT ON;     BEGIN TRY--------------------
AS
BEGIN
    SET NOCOUNT ON;
    BEGIN TRY---------------------开始捕捉异常
       BEIN TRAN------------------开始事务
        UPDATE A SET A.names = B.names FROM 表1 AS A INNER JOIN 表2 AS B ON A.id = B.id
        UPDATE A SET A.names = B.names FROM 表1 AS A INNER JOIN 表2 AS B ON A.TEST = B.TEST
    COMMIT TRAN -------提交事务
    END TRY-----------结束捕捉异常
    BEGIN CATCH------------有异常被捕获
        IF @@TRANCOUNT > 0---------------判断有没有事务
        BEGIN
            ROLLBACK TRAN----------回滚事务
        END
        EXEC YourLogErrorProcedure-----------执行存储过程将错误信息记录在表当中
    END CATCH--------结束异常处理
END
---------------------------------------------记录操作错信息的存储过程--------------------------------------------
CREATE PROCEDURE YourLogErrorProcedure
    @ErrorLogID [int] = 0 OUTPUT -- contains the ErrorLogID of the row inserted
AS                               -- by uspLogError in the ErrorLog table
BEGIN
    SET NOCOUNT ON;
    -- Output parameter value of 0 indicates that error
    -- information was not logged
    SET @ErrorLogID = 0;
    BEGIN TRY
        -- Return if there is no error information to log
        IF ERROR_NUMBER() IS NULL
            RETURN;
        -- Return if inside an uncommittable transaction.
        -- Data insertion/modification is not allowed when
        -- a transaction is in an uncommittable state.
        IF XACT_STATE() = -1
        BEGIN
            PRINT 'Cannot log error since the current transaction is in an uncommittable state. '
                + 'Rollback the transaction before executing uspLogError in order to successfully log error information.';
            RETURN;
        END
        INSERT [dbo].[OperateErrorLog]
            [OperateName],
            [ErrorNumber],
            [ErrorSeverity],
            [ErrorState],
            [ErrorProcedure],
            [ErrorLine],
            [ErrorMessage]
        VALUES
            CONVERT(sysname, CURRENT_USER),
            ERROR_NUMBER(),
            ERROR_SEVERITY(),
            ERROR_STATE(),
            ERROR_PROCEDURE(),
            ERROR_LINE(),
            ERROR_MESSAGE()
        SET @ErrorLogID = @@IDENTITY;
    END TRY
    BEGIN CATCH
        PRINT 'An error occurred in stored procedure uspLogError: ';
        EXECUTE YourPrintErrorProcedure;-----------------打印错误信息的存储过程
        RETURN -1;
    END CATCH
END;
CREATE PROCEDURE YourPrintErrorProcedure
AS
BEGIN
    SET NOCOUNT ON;
    -- Print error information.
    PRINT 'Error ' + CONVERT(varchar(50), ERROR_NUMBER()) +
          ', Severity ' + CONVERT(varchar(5), ERROR_SEVERITY()) +
          ', State ' + CONVERT(varchar(5), ERROR_STATE()) +
          ', Procedure ' + ISNULL(ERROR_PROCEDURE(), '-') +
          ', Line ' + CONVERT(varchar(5), ERROR_LINE());
    PRINT ERROR_MESSAGE();
END;
CREATE TABLE [dbo].[ErrorLog](
    [ErrorLogID] [int] IDENTITY(1,1) NOT NULL,
    [ErrorTime] [datetime] NOT NULL CONSTRAINT [DF_ErrorLog_ErrorTime]  DEFAULT (getdate()),
    [UserName] [sysname] COLLATE Chinese_PRC_CI_AS NOT NULL,
    [ErrorNumber] [int] NOT NULL,
    [ErrorSeverity] [int] NULL,
    [ErrorState] [int] NULL,
    [ErrorProcedure] [nvarchar](126) COLLATE Chinese_PRC_CI_AS NULL,
    [ErrorLine] [int] NULL,
    [ErrorMessage] [nvarchar](4000) COLLATE Chinese_PRC_CI_AS NOT NULL,
 CONSTRAINT [PK_ErrorLog_ErrorLogID] PRIMARY KEY CLUSTERED
    [ErrorLogID] ASC
)WITH (IGNORE_DUP_KEY = OFF) ON [PRIMARY]
) ON [PRIMARY]
本文来自CSDN博客,转载请标明出处:http://blog.csdn.net/WeiZhang_son_Ding/archive/2010/02/05/5291732.aspx
http://www.cnblogs.com/BpLoveGcy/archive/2010/03/22/1691407.html
ALTER PROC usp_AccountTransaction          @AccountNum INT,          @Amount DECIMAL      AS      BEGIN          BEGIN TRY --Start the Try Block..              BEGIN TRANSACTION -- Start the transaction..                  UPDATE MyChecking SET Amount = Amount - @Amount                      WHERE AccountNum = @AccountNum                  UPDATE MySavings SET Amount = Amount + @Amount                      WHERE AccountNum = @AccountNum              COMMIT TRAN -- Transaction Success!          END TRY          BEGIN CATCH              IF @@TRANCOUNT > 0                  ROLLBACK TRAN --RollBack in case of Error              -- you can Raise ERROR with RAISEERROR() Statement including the details of the exception              --RAISERROR(ERROR_MESSAGE(), ERROR_SEVERITY(), 1)
            DECLARE @ErrorMessage NVARCHAR(4000);
       DECLARE @ErrorSeverity INT;
     DECLARE @ErrorState INT;
     SELECT
      @ErrorMessage = ERROR_MESSAGE(),
      @ErrorSeverity = ERROR_SEVERITY(),
      @ErrorState = ERROR_STATE();
   -- Use RAISERROR inside the CATCH block to return error
   -- information about the original error that caused
   -- execution to jump to the CATCH block.
     RAISERROR (@ErrorMessage, -- Message text.
          @ErrorSeverity, -- Severity.
          @ErrorState -- State.
       END CATCH      END      GO
BEGIN TRY          SELECT GETDATE()          SELECT 1/0--Evergreen divide by zero example!      END TRY      BEGIN CATCH          SELECT 'There was an error! ' + ERROR_MESSAGE()          RETURN      END CATCH;
2.获得错误信息的函数表:
下面系统函数在CATCH块有效.可以用来得到更多的错误信息:
函数 描述 ERROR_NUMBER() 返回导致运行 CATCH 块的错误消息的错误号。 ERROR_SEVERITY() 返回导致 CATCH 块运行的错误消息的严重级别 ERROR_STATE() 返回导致 CATCH 块运行的错误消息的状态号 ERROR_PROCEDURE() 返回出现错误的存储过程名称 ERROR_LINE() 返回发生错误的行号 ERROR_MESSAGE() 返回导致 CATCH 块运行的错误消息的完整文本
  BEGIN TRY          Try Statement 1          Try Statement 2          ...          Try Statement M      END TRY      BEGIN CATCH          Catch Statement 1          Catch Statement 2          ...          Catch Statement N      END CATCH
