当前位置:首页 > 芯闻号 > 充电吧
[导读](1) SELECT 表名=case when a.colorder=1 then d.name else '' end, 表说明=case when a.colorder=1 then isnull
(1)
SELECT
表说明=case when a.colorder=1 then isnull(f.value,'') else '' end,
字段序号=a.colorder,
字段名=a.name,
标识=case when COLUMNPROPERTY( a.id,a.name,'IsIdentity')=1 then '√'else '' end,
主键=case when exists(SELECT 1 FROM sysobjects where xtype='PK' and parent_obj=a.id and name in (
SELECT name FROM sysindexes WHERE indid in(
SELECT indid FROM sysindexkeys WHERE id = a.id AND colid=a.colid
))) then '√' else '' end,
类型=b.name,
占用字节数=a.length,
长度=COLUMNPROPERTY(a.id,a.name,'PRECISION'),
小数位数=isnull(COLUMNPROPERTY(a.id,a.name,'Scale'),0),
允许空=case when a.isnullable=1 then '√'else '' end,
默认值=isnull(e.text,''),
字段说明=isnull(g.[value],'')
FROM syscolumns a
left join systypes b on a.xusertype=b.xusertype
inner join sysobjects d on a.id=d.id and d.xtype='U' and d.name<>'dtproperties'
left join syscomments e on a.cdefault=e.id
left join sysproperties g on a.id=g.id and a.colid=g.smallid
left join sysproperties f on d.id=f.id and f.smallid=0
--where d.name='要查询的表'   --如果只查询指定表,加上此条件
order by a.id,a.colorder
(2)
SQL2000系统表的应用
--1:获取当前数据库中的所有用户表
select Name from sysobjects where xtype='u' and status>=0
--2:获取某一个表的所有字段
select name from syscolumns where id=object_id('表名')
--3:查看与某一个表相关的视图、存储过程、函数
select a.* from sysobjects a, syscomments b where a.id = b.id and b.text like '%表名%'
--4:查看当前数据库中所有存储过程
select name as 存储过程名称 from sysobjects where xtype='P'
--5:查询用户创建的所有数据库
select * from master..sysdatabases D where sid not in(select sid from master..syslogins where name='sa')
或者
select dbid, name AS DB_NAME from master..sysdatabases where sid <> 0x01
--6:查询某一个表的字段和数据类型
select column_name,data_type from information_schema.columns
where table_name = '表名'
--7:取得表字段的描述
select name,
(select value from sysproperties where id = syscolumns.id and smallid=syscolumns.colid) as 描述
