当前位置:首页 > 芯闻号 > 充电吧
[导读]设置与获取为同一个方法,不传入参数为获取,传入参数为设置 input元素value:val方法 button //设置input的value $("#edittex
设置与获取
    //设置input的value
    $("#edittext").val("99");
    //获取input的value
    var ret = $("#edittext").val();
    console.log(ret);
常规元素text:html方法
hello
hello
    //设置a标签的text
    $(".a").html("99");
    //获取a标签的text
    var     ret = $(".a").html();
    console.log(ret);
    //设置p元素的text
    $(".p").html("pppppp");
    //获取a元素的text
    ret = $(".p").html();
    console.log(ret);
样式表:css方法 css(属性,值)
    var $obj =$(".a");
    //设置css的color属性
    $obj.css("color","red");
    //获取css的color属性 color类型返回 rgb(255,0,0) 类型string
    var m_color = $obj.css("color");
    console.log(m_color+"类型:"+typeof m_color);
迭代:
    var $obj =$(".a");
    for(var x=0;x<$obj.length;x++)
        $obj.eq(x).html("im index:"+x);
    $obj= $(".a");//可省略 前面已经得到
        console.log($obj.eq(x).html());
具体可查看jQuery var函数实现
val: function( value ) {
        var hooks, ret, isFunction,
            elem = this[ 0 ];
        if ( !arguments.length ) {
            if ( elem ) {
                hooks = jQuery.valHooks[ elem.type ] ||
                    jQuery.valHooks[ elem.nodeName.toLowerCase() ];
                if (
                    hooks &&
                    "get" in hooks &&
                    ( ret = hooks.get( elem, "value" ) ) !== undefined
                    return ret;
                ret = elem.value;
                return typeof ret === "string" ?
                    // handle most common string cases
                    ret.replace( rreturn, "" ) :
                    // handle cases where value is null/undef or number
                    ret == null ? "" : ret;
            return;
        isFunction = jQuery.isFunction( value );
        return this.each( function( i ) {
            var val;
            if ( this.nodeType !== 1 ) {
                return;
            if ( isFunction ) {
                val = value.call( this, i, jQuery( this ).val() );
            } else {
                val = value;
            // Treat null/undefined as ""; convert numbers to string
            if ( val == null ) {
                val = "";
            } else if ( typeof val === "number" ) {
                val += "";
            } else if ( jQuery.isArray( val ) ) {
                val = jQuery.map( val, function( value ) {
                    return value == null ? "" : value + "";
            hooks = jQuery.valHooks[ this.type ] || jQuery.valHooks[ this.nodeName.toLowerCase() ];
            // If set returns undefined, fall back to normal setting
            if ( !hooks || !( "set" in hooks ) || hooks.set( this, val, "value" ) === undefined ) {
                this.value = val;
