当前位置:首页 > 芯闻号 > 充电吧
[导读]题目链接:HDU 5762 题面: Teacher Bo Time Limit: 4000/2000 MS (Java/Others)    Memory Limit: 131072/131072
题目链接:HDU 5762
题面:
Teacher Bo Time Limit: 4000/2000 MS (Java/Others)    Memory Limit: 131072/131072 K (Java/Others)
Total Submission(s): 644    Accepted Submission(s): 353
Problem Description Teacher BoBo is a geography teacher in the school.One day in his class,he marked N points in the map,the i-th point is at (Xi,Yi).He wonders,whether there is a tetrad (A,B,C,D)(A
If there exists such tetrad,print "YES",else print "NO".
Input First line, an integer T. There are T test cases.(T≤50)
In each test case,the first line contains two intergers, N, M, means the number of points and the range of the coordinates.(N,M≤105).
Next N lines, the i-th line shows the coordinate of the i-th point.(Xi,Yi)(0≤Xi,Yi≤M).
Output T lines, each line is "YES" or "NO".
Sample Input
1 1
2 2
3 3
4 10
8 8
2 3
3 3
4 4
Sample Output
YES
NO
Source 2016 Multi-University Training Contest 3
题意:
     问给定的点中,是否存在两对点的曼哈顿距离完全相同,两对点不可以是同一对点。
解题:
     其实这题考察的就是暴力,只要抓住差值范围是在0-2*10^5范围内这一点就可以解决。看似n^2遍历,实则最多只会在2*10^5时停下来,用vis数组标记一下即可,如果出现点访问两次即有。
代码:
#include
#include
#include
#include
#include
#include
#define LL long long
using namespace std;
bool vis[200005];
int x[100005],y[100005];
int main()
	int t,n,m,tmp;
	bool flag=0;
	scanf("%d",&t);
	while(t--)
	  flag=0;
	  scanf("%d%d",&n,&m);
	  memset(vis,0,sizeof(vis));
	  for(int i=0;i
