HDU 5534 Partial Tree(动态规划)
题目链接:http://acm.hdu.edu.cn/showproblem.php?pid=5534
题面:
Partial Tree Time Limit: 2000/1000 MS (Java/Others) Memory Limit: 262144/262144 K (Java/Others)Total Submission(s): 763 Accepted Submission(s): 374
Problem Description In mathematics, and more specifically in graph theory, a tree is an undirected graph in which any two nodes are connected by exactly one path. In other words, any connected graph without simple cycles is a tree.
You find a partial tree on the way home. This tree has n nodes but lacks of n−1 edges. You want to complete this tree by adding n−1 edges. There must be exactly one path between any two nodes after adding. As you know, there are nn−2 ways to complete this tree, and you want to make the completed tree as cool as possible. The coolness of a tree is the sum of coolness of its nodes. The coolness of a node is f(d), where f is a predefined function and d is the degree of this node. What's the maximum coolness of the completed tree?
Input The first line contains an integer T indicating the total number of test cases.
Each test case starts with an integer n in one line,
then one line with n−1 integers f(1),f(2),…,f(n−1).
1≤T≤2015
2≤n≤2015
0≤f(i)≤10000
There are at most 10 test cases with n>100.
Output For each test case, please output the maximum coolness of the completed tree in one line.
Sample Input 2 3 2 1 4 5 1 4
Sample Output 5 19
Source 2015ACM/ICPC亚洲区长春站-重现赛(感谢东北师大)
题意:
给定一颗无向树的节点数和各个度对应的权值,定义酷度为每个节点的度数乘以相应的度对应的权值的总和,求最大酷度。
解题:
比较直接的想法是dp[i][j],表示前i个节点分配了j点度数能获取的最大值,写法清晰明了,可惜复杂度为n^3,明显超时。
结合树的特殊结构,每个节点的度数最少为1,因此预先给每个节点分配一点度数,随后再将剩余的2*(n-1)-n点度数分配,使之得到最大的酷度。
状态转移方程可以改进为dp[i],代表在原来均分了n点度数的基础上,再分配i点度数所能获取的最大酷度。因为已经保障了每个节点至少为1度,后续分配也不会出现多次替换的情况,因此省却了位置这一维,复杂度降为n^2.问题得解。
dp[i]=max(dp[i],dp[i-j]+f[j+1]-f[1]);
代码:
#include
#include
#include
#include
#include
using namespace std;
int f[2020],dp[2020];
int main()
int t,n,lim;
scanf("%d",&t);
while(t--)
memset(dp,0,sizeof(dp));
scanf("%d",&n);
for(int i=1;i
