当前位置:首页 > 芯闻号 > 充电吧
[导读]引入javamail包 1. 发送一封简单邮件 public void test1() { // 收件人电子邮箱 String to = "xxx@qq.co
引入javamail包
1. 发送一封简单邮件
    // 收件人电子邮箱    String to = "xxx@qq.com";
    // 发件人电子邮箱    String from = "xxx@126.com";
    // 指定发送邮件的主机    String host = "smtp.126.com";
    // 获取系统属性    Properties properties = System.getProperties();
    // 设置邮件服务器    properties.setProperty("mail.smtp.host", host);
    properties.put("mail.smtp.auth", "true");    // 获取默认session对象    Session session = Session.getDefaultInstance(properties, new Authenticator() {        public PasswordAuthentication getPasswordAuthentication() {            return new PasswordAuthentication("xxx@126.com", "xxx"); //发件人邮件用户名、密码        }    });
    try {        // 创建默认的 MimeMessage 对象        MimeMessage message = new MimeMessage(session);
        // Set From: 头部头字段        message.setFrom(new InternetAddress(from));
        // Set To: 头部头字段        message.addRecipient(Message.RecipientType.TO, new InternetAddress(to));
        // Set Subject: 头部头字段        message.setSubject("This is the Subject Line!");
        // 设置消息体        message.setText("This is actual message");
        // 发送消息        Transport.send(message);        System.out.println("Sent message successfully....from w3cschool.cc");    } catch (MessagingException mex) {        mex.printStackTrace();    }
2. 发送带附件的邮件
public class MailUtils {private String host      = ""; // smtp服务器private String from      = ""; // 发件人地址private String to        = ""; // 收件人地址private String affix     = ""; // 附件地址private String affixName = ""; // 附件名称private String user      = ""; // 用户名private String pwd       = ""; // 密码private String subject   = ""; // 邮件标题
public void setAddress(String from, String to, String subject) {    this.from = from;    this.to = to;    this.subject = subject;}
public void setAffix(String affix, String affixName) {    this.affix = affix;    this.affixName = affixName;}
public void send(String host, String user, String pwd) {    this.host = host;    this.user = user;    this.pwd = pwd;
    Properties props = new Properties();
    // 设置发送邮件的邮件服务器的属性(这里使用网易的smtp服务器)    props.put("mail.smtp.host", host);    // 需要经过授权,也就是有户名和密码的校验,这样才能通过验证(一定要有这一条)    props.put("mail.smtp.auth", "true");
    // 用刚刚设置好的props对象构建一个session    Session session = Session.getDefaultInstance(props);
    // 有了这句便可以在发送邮件的过程中在console处显示过程信息,供调试使    // 用(你可以在控制台(console)上看到发送邮件的过程)    session.setDebug(true);
    // 用session为参数定义消息对象    MimeMessage message = new MimeMessage(session);    try {        // 加载发件人地址        message.setFrom(new InternetAddress(from));        // 加载收件人地址        message.addRecipient(Message.RecipientType.TO, new InternetAddress(to));        // 加载标题        message.setSubject(subject);
        // 向multipart对象中添加邮件的各个部分内容,包括文本内容和附件        Multipart multipart = new MimeMultipart();
        // 设置邮件的文本内容        BodyPart contentPart = new MimeBodyPart();        contentPart.setText("邮件的具体内容在此");        multipart.addBodyPart(contentPart);        // 添加附件        BodyPart messageBodyPart = new MimeBodyPart();        DataSource source = new FileDataSource(affix);        // 添加附件的内容        messageBodyPart.setDataHandler(new DataHandler(source));        // 添加附件的标题        // 这里很重要,通过下面的Base64编码的转换可以保证你的中文附件标题名在发送时不会变成乱码        sun.misc.BASE64Encoder enc = new sun.misc.BASE64Encoder();        messageBodyPart.setFileName("=?GBK?B?" + enc.encode(affixName.getBytes()) + "?=");        multipart.addBodyPart(messageBodyPart);
        // 将multipart对象放到message中        message.setContent(multipart);        // 保存邮件        message.saveChanges();        // 发送邮件        Transport transport = session.getTransport("smtp");        // 连接服务器的邮箱        transport.connect(host, user, pwd);        // 把邮件发送出去        transport.sendMessage(message, message.getAllRecipients());        transport.close();    } catch (Exception e) {        e.printStackTrace();    }}
@org.junit.Test
public void testEmail() {MailUtils cn = new MailUtils();// 设置发件人地址、收件人地址和邮件标题cn.setAddress("xxx@126.com", "xxx@qq.com", "一个带附件的JavaMail邮件");// 设置要发送附件的位置和标题cn.setAffix("f:/123.txt", "123.txt");
/**      * 设置smtp服务器以及邮箱的帐号和密码      * 用QQ 邮箱作为发生者不好使 (原因不明)      * 163 邮箱可以,但是必须开启  POP3/SMTP服务 和 IMAP/SMTP服务      * 因为程序属于第三方登录,所以登录密码必须使用163的授权码      *    */    // 注意: [授权码和你平时登录的密码是不一样的]    cn.send("smtp.126.com", "xxx@126.com", "xxx");
Spring Boot中使用JavaMailSender发送邮件 1. 快速入门
在Spring Boot的工程中的pom.xml中引入spring-boot-starter-mail依赖:
如其他自动化配置模块一样,在完成了依赖引入之后,只需要在application.properties中配置相应的属性内容。
下面我们以QQ邮箱为例,在application.properties中加入如下配置(注意替换自己的用户名和密码):
通过单元测试来实现一封简单邮件的发送:
2. 进阶使用
在上例中,我们通过使用SimpleMailMessage实现了简单的邮件发送,但是实际使用过程中,我们还可能会带上附件、或是使用邮件模块等。这个时候我们就需要使用MimeMessage来设置复杂一些的邮件内容,下面我们就来依次实现一下。
发送附件
在上面单元测试中加入如下测试用例(通过MimeMessageHelper来发送一封带有附件的邮件):
@Test
public void sendAttachmentsMail() throws Exception {MimeMessage mimeMessage = mailSender.createMimeMessage();MimeMessageHelper helper = new MimeMessageHelper(mimeMessage, true);helper.setFrom("dyc87112@qq.com");helper.setTo("dyc87112@qq.com");helper.setSubject("主题:有附件");helper.setText("有附件的邮件");FileSystemResource file = new FileSystemResource(new File("weixin.jpg"));helper.addAttachment("附件-1.jpg", file);helper.addAttachment("附件-2.jpg", file);mailSender.send(mimeMessage);
嵌入静态资源
除了发送附件之外,我们在邮件内容中可能希望通过嵌入图片等静态资源,让邮件获得更好的阅读体验,而不是从附件中查看具体图片,下面的测试用例演示了如何通过MimeMessageHelper实现在邮件正文中嵌入静态资源。
@Test
public void sendInlineMail() throws Exception {MimeMessage mimeMessage = mailSender.createMimeMessage();MimeMessageHelper helper = new MimeMessageHelper(mimeMessage, true);helper.setFrom("dyc87112@qq.com");helper.setTo("dyc87112@qq.com");helper.setSubject("主题:嵌入静态资源");helper.setText("", true);FileSystemResource file = new FileSystemResource(new File("weixin.jpg"));helper.addInline("weixin", file);mailSender.send(mimeMessage);
这里需要注意的是addInline函数中资源名称weixin需要与正文中cid:weixin对应起来
模板邮件
通常我们使用邮件发送服务的时候,都会有一些固定的场景,比如重置密码、注册确认等,给每个用户发送的内容可能只有小部分是变化的。所以,很多时候我们会使用模板引擎来为各类邮件设置成模板,这样我们只需要在发送时去替换变化部分的参数即可。
在Spring Boot中使用模板引擎来实现模板化的邮件发送也是非常容易的,下面我们以velocity为例实现一下。
引入velocity模块的依赖:
        org.springframework.boot    spring-boot-starter-velocity
在resources/templates/下,创建一个模板页面template.vm:
你好, ${username}, 这是一封模板邮件!
我们之前在Spring Boot中开发Web应用时,提到过在Spring Boot的自动化配置下,模板默认位于resources/templates/目录下
最后,我们在单元测试中加入发送模板邮件的测试用例,具体如下:
@Test
public void sendTemplateMail() throws Exception {MimeMessage mimeMessage = mailSender.createMimeMessage();MimeMessageHelper helper = new MimeMessageHelper(mimeMessage, true);helper.setFrom("dyc87112@qq.com");helper.setTo("dyc87112@qq.com");helper.setSubject("主题:模板邮件");Map model = new HashedMap();model.put("username", "didi");String text = VelocityEngineUtils.mergeTemplateIntoString(        velocityEngine, "template.vm", "UTF-8", model);helper.setText(text, true);mailSender.send(mimeMessage);
尝试运行一下,就可以收到内容为你好, didi, 这是一封模板邮件!的邮件。这里,我们通过传入username的参数,在邮件内容中替换了模板中的${username}变量。
