使用JAVA将数据库导出到Excel文档
首先将要导出的数据库表的数据封装到一个list集合中,然后循环遍历该list集合
再应用jxl组件将这些数据写入excel文件。
001
package
com.ybhacker.mailbox.util;
002
003
import
java.io.File;
004
import
java.util.List;
005
006
import
jxl.*;
007
import
jxl.format.Alignment;
008
import
jxl.format.Colour;
009
import
jxl.format.UnderlineStyle;
010
import
jxl.format.VerticalAlignment;
011
import
jxl.write.Label;
012
import
jxl.write.WritableFont;
013
import
jxl.write.WritableSheet;
014
import
jxl.write.WritableWorkbook;
015
016
import
com.ybhacker.mailbox.model.BoxList;
017
018
019
* Excel操作
020
021
* @author Windows7
022
023
024
public
class
ExcelOperationUtil {
025
026
027
* 保存数据内容到excel
028
* @param list
029
* @param savepath
030
* @return
031
032
033
public
boolean
readDataToExcelFile(List
034
try
035
WritableWorkbook book = Workbook.createWorkbook(
new
File(savepath));
036
WritableSheet sheet = book.createSheet(
"SHELL"
// 设置字体样式
038
jxl.write.WritableFont font =
new
jxl.write.WritableFont(
039
WritableFont.ARIAL,
15
, WritableFont.BOLD,
false
040
UnderlineStyle.NO_UNDERLINE, jxl.format.Colour.GREEN);
041
jxl.write.WritableCellFormat cellFormat =
new
jxl.write.WritableCellFormat(
042
font);
043
cellFormat.setAlignment(Alignment.CENTRE);
044
cellFormat.setVerticalAlignment(VerticalAlignment.CENTRE);
// 设置单元格内容两端对齐
045
cellFormat.setBackground(Colour.GRAY_25);
// 背景颜色
046
Label label_title =
new
Label(
"WEBSHELL收信箱子系统V2.0"
047
cellFormat);
048
sheet.mergeCells(
// 合并第一行的第1个到第5个单元格
049
sheet.setRowView(
false
// 设置第一行的行高
050
051
Label label_id =
new
Label(
"ID"
052
Label label_url =
new
Label(
"木马地址"
053
Label label_script =
new
Label(
"脚本类型"
054
Label label_pass =
new
Label(
"密码"
055
Label label_host =
new
Label(
"域名"
056
Label label_google =
new
Label(
"谷歌权重"
057
Label label_baidu =
new
Label(
"百度权重"
058
Label label_indexed =
new
Label(
"收录总数"
059
Label label_createtime =
new
Label(
"创建时间"
060
Label label_sell =
new
Label(
"是否出售"
061
062
sheet.setColumnView(
// 设置列宽
063
sheet.addCell(label_title);
064
sheet.addCell(label_id);
065
sheet.addCell(label_url);
066
sheet.addCell(label_script);
067
sheet.addCell(label_pass);
068
sheet.addCell(label_host);
069
sheet.addCell(label_google);
070
sheet.addCell(label_baidu);
071
sheet.addCell(label_indexed);
072
sheet.addCell(label_createtime);
073
sheet.addCell(label_sell);
074
075
for
int
i =
; i < list.size(); i++) {
// 遍历数据对象的集合,将所有信息导出到Excel
076
BoxList temp = (BoxList) list.get(i);
077
String script =
"未知"
078
String createtime = temp.getnCreateTime().toString();
079
if
(temp.getnScript() ==
script =
"ASP"
081
082
if
script =
"PHP"
084
085
if
script =
"ASPX"
087
088
if
script =
"JSP"
090
091
String Sell =
"正常"
092
if
(temp.isnSell()) {
093
Sell =
"已售"
094
095
Label id_value =
new
Label(
, i +
, temp.getId() +
096
Label url_value =
new
Label(
, i +
, temp.getnUrl());
097
Label script_value =
new
Label(
, i +
, script);
098
Label pass_value =
new
Label(
, i +
, temp.getnPass());
099
Label host_value =
new
Label(
, i +
, temp.getnHost());
100
Label google_value =
new
Label(
, i +
, temp.getnGoogle());
101
Label baidu_value =
new
Label(
, i +
, temp.getnBaidu());
102
Label indexed_value =
new
Label(
, i +
, temp.getnIndexed());
103
Label createtime_value =
new
Label(
, i +
, createtime);
104
Label sell_value =
new
Label(
, i +
, Sell);
105
106
sheet.addCell(id_value);
107
sheet.addCell(url_value);
108
sheet.addCell(script_value);
109
sheet.addCell(pass_value);
110
sheet.addCell(host_value);
111
sheet.addCell(google_value);
112
sheet.addCell(baidu_value);
113
sheet.addCell(indexed_value);
114
sheet.addCell(createtime_value);
115
sheet.addCell(sell_value);
116
117
118
book.write();
119
book.close();
120
return
true
121
catch
(Exception e) {
122
System.out.println(
"异常信息:"
+ e.getMessage());
123
e.printStackTrace();
124
return
false
125
126
127
