WINCE中DataGrid对SQLCE数据库的操作
private SqlCeConnection OpenSQLCE()
//存取数据库
//连接sql server Mobile数据库的连接字符串
string connString = "Data Source='singleinfo.sdf';Password=";
SqlCeEngine engine = new SqlCeEngine(connString);
//建立链接
SqlCeConnection ConnMobile = new SqlCeConnection(connString);
try
ConnMobile.Open();
catch (Exception ex)
MessageBox.Show("不能正确连接数据库!" + ex.Message);
this.Close();
throw;
return ConnMobile;
//统计表中的数据元组总数
string Strnum = "select count(*) from SingleDatas where Commandeco is not null";
SqlCeCommand CommandNum = new SqlCeCommand(Strnum, ConnMobile);
string TotalLine = CommandNum.ExecuteScalar().ToString();
labelNum.Text = Convert.ToString(TotalLine); // 显示数据记录总数
int b = Convert.ToInt32(TotalLine);
if (0 == b)
tableRow = b + 1;
else
//获取最大的Commandeco值
string strcmd = "Select max(Commandeco) from SingleDatas";
SqlCeCommand commd = new SqlCeCommand(strcmd, ConnMobile);
string A = commd.ExecuteScalar().ToString();
tableRow = Convert.ToInt32(A) + 1;
//MessageBox.Show("插入第一条数据:" + tableRow.ToString());
string sql = "Insert into SingleDatas (Commandeco,Tosend,Received) values (" + tableRow + ",'" + Convert.ToString(sendmsg.Text) + "','" + Convert.ToString(recmsg.Text) + "')";
SqlCeCommand command = new SqlCeCommand(sql, ConnMobile);
int r = command.ExecuteNonQuery(); //插入数据影响行
if (r > 0)
MessageBox.Show("添加数据成功!");
//在DataGrid1显示数据
string str = "select * from SingleDatas";
DataSet dataset = new DataSet();
SqlCeDataAdapter adapter = new SqlCeDataAdapter(str, ConnMobile);
try
adapter.Fill(dataset, "SingleDatas");
dataGrid1.DataSource = dataset.Tables["SingleDatas"];
MessageBox.Show("出错信息" + ex.Message);
this.Close();
throw;
ConnMobile.Close();
SqlCeConnection connMbile = OpenSQLCE();
try
//获取当前选中行的ID值。
string myID = this.dataGrid1[dataGrid1.CurrentCell.RowNumber, 2].ToString().Trim();
MessageBox.Show("你将删除第" + myID + "元组");
// string MyDelete = "Delete from SingleDatas where Commandeco=" + dataGrid1.CurrentCell.RowNumber; //删除当前选中的行数的
string MyDelete = "Delete from SingleDatas where Commandeco=" + Convert.ToInt32(myID);
SqlCeCommand MyCommand = new SqlCeCommand(MyDelete, connMbile);
MyCommand.ExecuteNonQuery();
Console.WriteLine("{0} Exception caught.", ex);
