当前位置:首页 > 芯闻号 > 充电吧
[导读]从数据库导出大量数据记录保存到文件的方法和实例数据库脚本:-- Table "t_test" DDLCREATE TABLE `t_test` (  `id` int(11) NOT NULL AUT
数据库脚本:
  `id` int(11) NOT NULL AUTO_INCREMENT,
  `title` varchar(255) DEFAULT NULL,
  `createTime` bigint(20) DEFAULT NULL,
  PRIMARY KEY (`id`)
) ENGINE=InnoDB  DEFAULT CHARSET=utf8;
代码:
package com.yanek.test;
import java.io.BufferedReader;
import java.io.File;
import java.io.FileOutputStream;
import java.io.FileReader;
import java.io.IOException;
import java.io.OutputStreamWriter;
import java.sql.Connection;
import java.sql.DriverManager;
import java.sql.PreparedStatement;
import java.sql.ResultSet;
import java.sql.SQLException;
import java.sql.Statement;
public class TestDB {
	public static void main(String[] args) {
		Test();  // 生成测试数据
		//Exp();
		//Exp(0);
		//System.out.println(readText("/opt/id.txt"));
	 * 导出数据
	 public static void Exp() {
			Connection Conn=null;
			try {
				Class.forName("com.mysql.jdbc.Driver").newInstance();
				String jdbcUrl = "jdbc:mysql://127.0.0.1:3306/testcms?characterEncoding=GBK";
				String jdbcUsername = "root";
				String jdbcPassword = "root";
				Conn = DriverManager.getConnection(jdbcUrl, jdbcUsername, jdbcPassword);
				System.out.println("conn"+Conn);
				Exp(Conn);
			} catch (SQLException e) {
				e.printStackTrace();
			catch (InstantiationException e) {
				// TODO Auto-generated catch block
			} catch (IllegalAccessException e) {
			} catch (ClassNotFoundException e) {
			finally
				try {
					Conn.close();
	 public static void Exp(int startid) {
			try {
				Exp(Conn,startid);
			finally
				try {
					Conn.close();
	  * 导出从startid开始的数据
	  * @param conn
	  * @param start_id
	 public static void Exp(Connection conn,int start_id) {
			int counter = 0;
			int startid=start_id;
			boolean flag = true;
			while (flag) {
				flag = false;
				String Sql = "SELECT * FROM t_test WHERE id>"
						+ startid + " order by id asc LIMIT 50";
				System.out.println("sql===" + Sql);
				try {
					Statement stmt = conn.createStatement();
					ResultSet rs = stmt.executeQuery(Sql);
						while (rs.next()) {
							flag = true;
							int id = rs.getInt("id");
							String title = rs.getString("title");
							startid = id ;
							counter++;
							writeContent(counter+"--id--"+id+"--title-"+title+"rn", "/opt/","log.txt",true);
							System.out.println("i="+counter+"--id--"+id+"--title-"+title);
					rs.close();
					stmt.close();
			writeContent(""+startid, "/opt/","id.txt",false);
	  * 导出一小时内的数据
	  * @param conn
	 public static void Exp(Connection conn) {
			int counter = 0;
			//一小时内的数据
			Long timestamp = System.currentTimeMillis() - (60 * 60 * 1000);
			while (flag) {
				flag = false;
				String Sql = "SELECT * FROM t_test WHERE createTime>"
						+ timestamp + " LIMIT 50";
				try {
					while (rs.next()) {
						flag = true;
						Long lastmodifytime = rs.getLong("createTime");
						timestamp = lastmodifytime;
						counter++;
					rs.close();
					stmt.close();
	 public static void Test() {
			try {
				for(int i=1;i<=10000;i++)
					add(Conn,"testTitle"+i+"-"+System.currentTimeMillis());
			finally
				try {
					Conn.close();
	 public static void add(Connection conn,String title)
	    	PreparedStatement pstmt = null;
			String insert_sql = "insert into t_test(title,createTime) values (?,?)";
			System.out.println("sql="+insert_sql);
			try {
				pstmt = conn.prepareStatement(insert_sql);
				pstmt.setString(1,title);
				pstmt.setLong(2,System.currentTimeMillis());
				int ret = pstmt.executeUpdate();
			finally{
				try {
					pstmt.close();
		 * 写入内容到文件
		 * @param number
		 * @param filename
		 * @return
		public static boolean writeContent(String c, String dirname,String filename,boolean isAppend) {
			File f=new File(dirname);
			if (!f.exists())
					f.mkdirs();
			try {
				FileOutputStream fos = new FileOutputStream( dirname+File.separator+filename,isAppend);
				OutputStreamWriter writer = new OutputStreamWriter(fos);
				writer.write(c);
				writer.close();
				fos.close();
			} catch (IOException e) {
				return false;
			return true;
		 * 从文件读取内容
		 * @param filename
		 * @return
		public static String readText(String filename) {
			String content = "";
			try {
				File file = new File(filename);
				if (file.exists()) {
					FileReader fr = new FileReader(file);
					BufferedReader br = new BufferedReader(fr);
					String str = "";
					String newline = "";
					while ((str = br.readLine()) != null) {
						content += newline + str;
						newline = "n";
					br.close();
					fr.close();
			return content;
基本内思想: 就是通过记录开始记录id,执行多次sql来处理. 由于大数据量所以不能使用一条sql语句来输出.否则会内存不足导致错误.
主要用途: 可以使用在做接口开发时,给第三方提供数据增量输出的场景使用.
有问题可以联系qq: 1046011462
