mvc项目中实现备份数据库(sqlserver2005)
最近在项目中遇到一个问题,本人菜鸟不会解决,在此归纳整理一下,方便以后看看,顺便也许能帮上一些受此困扰的菜鸟们!
功能要求:mvc项目,实现数据库备份(bak文件)
实现步骤:数据库备份
方法:1、新建类DatabaseMaintenance
////// 数据库维护 ///public class DatabaseMaintenance { ////// 备份数据库 //////备份文件的路径public static void Backup(string fileName) { //TODO SQL Server only now string sqlConnectionString = ConfigurationManager.ConnectionStrings["HelpStoreContext"].ToString(); using (SqlConnection conn = new SqlConnection(sqlConnectionString)) { string dbName = new SqlConnectionStringBuilder(sqlConnectionString).InitialCatalog; ; string commandText = string.Format( "BACKUP DATABASE [{0}] TO DISK = '{1}' WITH FORMAT", dbName, fileName); DbCommand dbCommand = new SqlCommand(commandText, conn); if (conn.State != ConnectionState.Open) conn.Open(); dbCommand.ExecuteNonQuery(); } } ////// 还原数据库 database //////要还原的数据库文件路径public static void RestoreBackup(string fileName) { string sqlConnectionString = ConfigurationManager.AppSettings["HelpStoreContext"]; using (SqlConnection conn = new SqlConnection(sqlConnectionString)) { string dbName = new SqlConnectionStringBuilder(sqlConnectionString).InitialCatalog; string commandText = string.Format( "DECLARE @ErrorMessage NVARCHAR(4000)n" + "ALTER DATABASE [{0}] SET SINGLE_USER WITH ROLLBACK IMMEDIATEn" + "BEGIN TRYn" + "RESTORE DATABASE [{0}] FROM DISK = '{1}' WITH REPLACEn" + "END TRYn" + "BEGIN CATCHn" + "SET @ErrorMessage = ERROR_MESSAGE()n" + "END CATCHn" + "ALTER DATABASE [{0}] SET MULTI_USER WITH ROLLBACK IMMEDIATEn" + "IF (@ErrorMessage is not NULL)n" + "BEGINn" + "RAISERROR (@ErrorMessage, 16, 1)n" + "END", dbName, fileName); DbCommand dbCommand = new SqlCommand(commandText, conn); if (conn.State != ConnectionState.Open) conn.Open(); dbCommand.ExecuteNonQuery(); } //clear all pools SqlConnection.ClearAllPools(); } }
2、在控制器里调用方法
//备份数据库 public string BackupData() { try { var dname = DateTime.Now.Ticks; string filename = Server.MapPath("~/Data/" + dname + ".bak"); if (!System.IO.File.Exists(filename)) { System.IO.File.Create(filename); } DatabaseMaintenance.Backup(filename); return "备份成功"; } catch { return "备份失败"; } }
3、删除已经备份的数据库bak文件
//删除数据库备份文件 public string DelDataBase(string id) { try { string filepath=Server.MapPath("~/Data/"+id); System.IO.File.Delete(filepath); return "删除成功"; } catch { return "删除失败"; } }
