Android Studio 导入 Eclipse 的代码后,运行时中文显示乱码
Android Studio 导入 Eclipse 的代码后,先是编辑框中中文显示乱码。
运行后,程序中的中文又出现乱码的情况。
最后,还是在网上查找到解决方法,如下:
apply plugin: 'android' dependencies { compile fileTree(dir: 'libs', include: '*.jar') compile project(':appcompat_v7') } android { compileSdkVersion 10 buildToolsVersion "20.0.0" android {compileOptions.encoding = "GBK"} /////////增加的内容,可以解决部署到设备上汉字显示乱码的问题 compileOptions { sourceCompatibility JavaVersion.VERSION_1_7 targetCompatibility JavaVersion.VERSION_1_7 } sourceSets { main { manifest.srcFile 'AndroidManifest.xml' java.srcDirs = ['src'] resources.srcDirs = ['src'] aidl.srcDirs = ['src'] renderscript.srcDirs = ['src'] res.srcDirs = ['res'] assets.srcDirs = ['assets'] } // Move the tests to tests/java, tests/res, etc... instrumentTest.setRoot('tests') // Move the build types to build-types/// For instance, build-types/debug/java, build-types/debug/AndroidManifest.xml, ... // This moves them out of them default location under src//... which would // conflict with src/ being used by the main source set. // Adding new build types or product flavors should be accompanied // by a similar customization. debug.setRoot('build-types/debug') release.setRoot('build-types/release') } }
