关于Oracle数据库中的employee实例表
Oracle数据库安装的时候会自带一个练习用数据库(其中包含employee表,后来版本中此表改名为emp);
首先在安装过程中应该有个选项“是否安装实例表”(完全安装模式下默认是选择的),需要选择才有此表;
此表归属于scott账户,scott用户默认口令为tiger
如果发现scott账户已过期(Oracle 10g中经常发生),或口令不正确,可以通过以下方法进行设置
Sql代码 --账户解锁
alter user scott account unlock;
--重设scott账户口令为tiger
alter user scott identified by tiger;
附:实例表建表语句(适用于Oracle)
Sql代码 ----------------------demobld.sql begin-----------------------
-- Copyright (c) Oracle Corporation 1988, 2000. All Rights Reserved.
-- NAME
-- demobld.sql
-- DESCRIPTION
-- This script. creates the SQL*Plus demonstration tables in the
-- current schema. It should be STARTed by each user wishing to
-- access the tables. To remove the tables use the demodrop.sql
-- script.
-- USAGE
-- From within SQL*Plus, enter:
-- START demobld.sql
SET TERMOUT ON
PROMPT Building demonstration tables. Please wait.
SET TERMOUT OFF
DROP TABLE EMP;
DROP TABLE DEPT;
DROP TABLE BONUS;
DROP TABLE SALGRADE;
DROP TABLE DUMMY;
CREATE TABLE EMP
(EMPNO NUMBER(4) NOT NULL,
ENAME VARCHAR2(10),
JOB VARCHAR2(9),
MGR NUMBER(4),
HIREDATE DATE,
SAL NUMBER(7, 2),
COMM NUMBER(7, 2),
DEPTNO NUMBER(2));
INSERT INTO EMP VALUES
(7369, 'SMITH', 'CLERK', 7902,
TO_DATE('17-DEC-1980', 'DD-MON-YYYY'), 800, NULL, 20);
(7499, 'ALLEN', 'SALESMAN', 7698,
TO_DATE('20-FEB-1981', 'DD-MON-YYYY'), 1600, 300, 30);
(7521, 'WARD', 'SALESMAN', 7698,
TO_DATE('22-FEB-1981', 'DD-MON-YYYY'), 1250, 500, 30);
(7566, 'JONES', 'MANAGER', 7839,
TO_DATE('2-APR-1981', 'DD-MON-YYYY'), 2975, NULL, 20);
(7654, 'MARTIN', 'SALESMAN', 7698,
TO_DATE('28-SEP-1981', 'DD-MON-YYYY'), 1250, 1400, 30);
(7698, 'BLAKE', 'MANAGER', 7839,
TO_DATE('1-MAY-1981', 'DD-MON-YYYY'), 2850, NULL, 30);
(7782, 'CLARK', 'MANAGER', 7839,
TO_DATE('9-JUN-1981', 'DD-MON-YYYY'), 2450, NULL, 10);
(7788, 'SCOTT', 'ANALYST', 7566,
TO_DATE('09-DEC-1982', 'DD-MON-YYYY'), 3000, NULL, 20);
(7839, 'KING', 'PRESIDENT', NULL,
TO_DATE('17-NOV-1981', 'DD-MON-YYYY'), 5000, NULL, 10);
(7844, 'TURNER', 'SALESMAN', 7698,
TO_DATE('8-SEP-1981', 'DD-MON-YYYY'), 1500, 0, 30);
(7876, 'ADAMS', 'CLERK', 7788,
TO_DATE('12-JAN-1983', 'DD-MON-YYYY'), 1100, NULL, 20);
(7900, 'JAMES', 'CLERK', 7698,
TO_DATE('3-DEC-1981', 'DD-MON-YYYY'), 950, NULL, 30);
(7902, 'FORD', 'ANALYST', 7566,
TO_DATE('3-DEC-1981', 'DD-MON-YYYY'), 3000, NULL, 20);
(7934, 'MILLER', 'CLERK', 7782,
TO_DATE('23-JAN-1982', 'DD-MON-YYYY'), 1300, NULL, 10);
CREATE TABLE DEPT
(DEPTNO NUMBER(2),
DNAME VARCHAR2(14),
LOC VARCHAR2(13) );
INSERT INTO DEPT VALUES (10, 'ACCOUNTING', 'NEW YORK');
INSERT INTO DEPT VALUES (20, 'RESEARCH', 'DALLAS');
INSERT INTO DEPT VALUES (30, 'SALES', 'CHICAGO');
INSERT INTO DEPT VALUES (40, 'OPERATIONS', 'BOSTON');
CREATE TABLE BONUS
(ENAME VARCHAR2(10),
JOB VARCHAR2(9),
SAL NUMBER,
COMM NUMBER);
CREATE TABLE SALGRADE
(GRADE NUMBER,
LOSAL NUMBER,
HISAL NUMBER);
INSERT INTO SALGRADE VALUES (1, 700, 1200);
INSERT INTO SALGRADE VALUES (2, 1201, 1400);
INSERT INTO SALGRADE VALUES (3, 1401, 2000);
INSERT INTO SALGRADE VALUES (4, 2001, 3000);
INSERT INTO SALGRADE VALUES (5, 3001, 9999);
CREATE TABLE DUMMY
(DUMMY NUMBER);
INSERT INTO DUMMY VALUES (0);
COMMIT;
SET TERMOUT ON
PROMPT Demonstration table build is complete.
EXIT
-------------------demobld.sql end-----------------------
实例建表语句(适用于MySQL)
Sql代码 DROP TABLE employee;
DROP TABLE dept;
DROP TABLE bonus;
DROP TABLE salgrade;
DROP TABLE dummy;
CREATE TABLE employee
employeeno DECIMAL(4) NOT NULL,
ename VARCHAR(10),
job VARCHAR(9),
mgr DECIMAL(4),
hiredate DATE,
sal DECIMAL(7, 2),
comm DECIMAL(7, 2),
deptno DECIMAL(2)
INSERT INTO employee VALUES
(7369, 'SMITH', 'CLERK', 7902, '1980-12-17', 800, NULL, 20);
(7499, 'ALLEN', 'SALESMAN', 7698,'1981-2-20', 1600, 300, 30);
(7521, 'WARD', 'SALESMAN', 7698, '1981-2-22', 1250, 500, 30);
(7566, 'JONES', 'MANAGER', 7839, '1981-4-2', 2975, NULL, 20);
(7654, 'MARTIN', 'SALESMAN', 7698, '1981-9-28', 1250, 1400, 30);
(7698, 'BLAKE', 'MANAGER', 7839, '1981-5-1', 2850, NULL, 30);
(7782, 'CLARK', 'MANAGER', 7839, '1981-7-9', 2450, NULL, 10);
(7788, 'SCOTT', 'ANALYST', 7566, '1982-12-9', 3000, NULL, 20);
(7839, 'KING', 'PRESIDENT', NULL, '1981-11-17', 5000, NULL, 10);
(7844, 'TURNER', 'SALESMAN', 7698, '1981-9-8', 1500, 0, 30);
(7876, 'ADAMS', 'CLERK', 7788, '1983-1-12', 1100, NULL, 20);
(7900, 'JAMES', 'CLERK', 7698, '1981-12-3', 950, NULL, 30);
(7902, 'FORD', 'ANALYST', 7566, '1981-12-3', 3000, NULL, 20);
(7934, 'MILLER', 'CLERK', 7782, '1982-1-23', 1300, NULL, 10);
CREATE TABLE dept
(deptno DECIMAL(2),
dname VARCHAR(14),
loc VARCHAR(13) );
INSERT INTO dept VALUES (10, 'ACCOUNTING', 'NEW YORK');
INSERT INTO dept VALUES (20, 'RESEARCH', 'DALLAS');
INSERT INTO dept VALUES (30, 'SALES', 'CHICAGO');
INSERT INTO dept VALUES (40, 'OPERATIONS', 'BOSTON');
CREATE TABLE bonus
(ename VARCHAR(10),
job VARCHAR(9),
sal DECIMAL,
comm DECIMAL);
CREATE TABLE salgrade
(grade DECIMAL,
losal DECIMAL,
hisal DECIMAL);
INSERT INTO salgrade VALUES (1, 700, 1200);
INSERT INTO salgrade VALUES (2, 1201, 1400);
INSERT INTO salgrade VALUES (3, 1401, 2000);
INSERT INTO salgrade VALUES (4, 2001, 3000);
INSERT INTO salgrade VALUES (5, 3001, 9999);
CREATE TABLE dummy
(dummy DECIMAL);
INSERT INTO dummy VALUES (0);
