当前位置:首页 > 芯闻号 > 充电吧
[导读]ListView 点击响应代码(如下),以前都是正确的:private class MusicListItemClickListener implements OnItemClickListener
private class MusicListItemClickListener implements OnItemClickListener {
	@Override
	public void onItemClick(AdapterView parent, View view, int position,long id) {
在新的工程使用时,先提示 onItemClick 需要删除 @Override。我直接将 onItemClick 删除,再自动增加函数时,发现自动增加的函数变成如下所示的,参数的参数发生了变化,特别是第一个参数,由 AdapterView 变成 AdapterViewCompat。代码不再提示错误,运行之!
private class contactsListItemClickListener implements OnItemClickListener {		// AdapterViewCompat.OnItemClickListener
	@Override
	public void onItemClick(AdapterViewCompat arg0, View arg1, int arg2,
			long arg3) {
		// TODO Auto-generated method stub
		int position = arg2;
		int id = (int) arg3;
		Log.i(phoneBookInfo.TAG, "position: " + Integer.toString(position) + " id: " + Integer.toString(id));
运行时出现错误。提示如下:
D/AndroidRuntime(19395): Shutting down VM
 W/dalvikvm(19395): threadid=1: thread exiting with uncaught exception (group=0x4001b6a8)
 E/AndroidRuntime(19395): FATAL EXCEPTION: main
 E/AndroidRuntime(19395): java.lang.RuntimeException: Unable to start activity ComponentInfo{com.hs.leozheng.backuprecords/com.hs.leozheng.backuprecords.MainActivity}: java.lang.ClassCastException: com.hs.leozheng.backuprecords.MainActivity$contactsListItemClickListener
 E/AndroidRuntime(19395): 	at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:1734)
 E/AndroidRuntime(19395): 	at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:1753)
 E/AndroidRuntime(19395): 	at android.app.ActivityThread.access$1500(ActivityThread.java:155)
 E/AndroidRuntime(19395): 	at android.app.ActivityThread$H.handleMessage(ActivityThread.java:999)
 E/AndroidRuntime(19395): 	at android.os.Handler.dispatchMessage(Handler.java:130)
 E/AndroidRuntime(19395): 	at android.os.Looper.loop(SourceFile:351)
 E/AndroidRuntime(19395): 	at android.app.ActivityThread.main(ActivityThread.java:3820)
 E/AndroidRuntime(19395): 	at java.lang.reflect.Method.invokeNative(Native Method)
 E/AndroidRuntime(19395): 	at java.lang.reflect.Method.invoke(Method.java:538)
 E/AndroidRuntime(19395): 	at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:969)
 E/AndroidRuntime(19395): 	at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:727)
 E/AndroidRuntime(19395): 	at dalvik.system.NativeStart.main(Native Method)
 E/AndroidRuntime(19395): Caused by: java.lang.ClassCastException: com.hs.leozheng.backuprecords.MainActivity$contactsListItemClickListener
 E/AndroidRuntime(19395): 	at com.hs.leozheng.backuprecords.MainActivity.findViews(MainActivity.java:140)
 E/AndroidRuntime(19395): 	at com.hs.leozheng.backuprecords.MainActivity.onCreate(MainActivity.java:57)
 E/AndroidRuntime(19395): 	at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1082)
 E/AndroidRuntime(19395): 	at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:1698)
 E/AndroidRuntime(19395): 	... 11 more
对比之前的代码,与现在的代码,发现可能是 AdapterViewCompat 引起的。所以强制将 OnItemClickListener 声明为 AdapterView 的成员,如下:
private class contactsListItemClickListener implements AdapterView.OnItemClickListener {
	@Override
			long id) {
		Log.i(phoneBookInfo.TAG, "position: " + Integer.toString(position) + " id: " + Long.toString(id));
这样自动增加的 onItemClick 函数终于和以前一样了。
运行之,正确!
