当前位置:首页 > 芯闻号 > 充电吧
[导读]对象优先在Eden分配大多数情况下,对象在新生代Eden区中分配。当Eden区没有足够空间进行分配时,虚拟机将发起一次Minor GC。-Xms20M -Xmx20M -Xmn10M -XX:+Pri
对象优先在Eden分配
-Xms20M -Xmx20M -Xmn10M -XX:+PrintGCDetails -XX:SurvivorRatio=8
    @Test
    public void test3() {
        int _1MB=1024*1024;
        byte[]allocation1,allocation2,allocation3,allocation4;
        allocation1=new byte[2*_1MB];
        allocation2=new byte[2*_1MB];
        allocation3=new byte[2*_1MB];
        allocation4=new byte[4*_1MB];//出现一次Minor GC
---- IntelliJ IDEA coverage runner ----
sampling ...
include patterns:
exclude patterns:
[GC [PSYoungGen: 8192K->1014K(9216K)] 8192K->2401K(19456K), 0.0030996 secs] [Times: user=0.00 sys=0.00, real=0.03 secs] Heap
 PSYoungGen      total 9216K, used 6745K [0x00000000ff600000, 0x0000000100000000, 0x0000000100000000)
  eden space 8192K, 69% used [0x00000000ff600000,0x00000000ffb98da0,0x00000000ffe00000)
  from space 1024K, 99% used [0x00000000ffe00000,0x00000000ffefd878,0x00000000fff00000)
  to   space 1024K, 0% used [0x00000000fff00000,0x00000000fff00000,0x0000000100000000)
ParOldGen       total 10240K, used 1387K [0x00000000fec00000, 0x00000000ff600000, 0x00000000ff600000)
  object space 10240K, 13% used [0x00000000fec00000,0x00000000fed5aef0,0x00000000ff600000)
PSPermGen       total 21248K, used 5235K [0x00000000f9a00000, 0x00000000faec0000, 0x00000000fec00000)
  object space 21248K, 24% used [0x00000000f9a00000,0x00000000f9f1cd20,0x00000000faec0000)
[GC[DefNew:6651K->148K(9216K),0.0070106 secs]6651K->6292K(19456K), 0.0070426 secs]
[Times:user=0.00 sys=0.00,real=0.00 secs] Heap
def new generation total 9216K,used 4326K[0x029d0000,0x033d0000,0x033d0000)
eden space 8192K,51%used[0x029d0000,0x02de4828,0x031d0000)
from space 1024K,14%used[0x032d0000,0x032f5370,0x033d0000)
to space 1024K,0%used[0x031d0000,0x031d0000,0x032d0000)
tenured generation total 10240K,used 6144K[0x033d0000,0x03dd0000,0x03dd0000)
the space 10240K,60%used[0x033d0000,0x039d0030,0x039d0200,0x03dd0000)
compacting perm gen total 12288K,used 2114K[0x03dd0000,0x049d0000,0x07dd0000)
the space 12288K,17%used[0x03dd0000,0x03fe0998,0x03fe0a00,0x049d0000)
No shared spaces configured.
尝试分配3个2MB大小和1个4MB大小的对象,在运行时通过-Xms20M、-Xmx20M、-Xmn10M这3个参数限制了Java堆大小为20MB,不可扩展,其中10MB分配给新生代,剩下的10MB分配给老年代。-XX:SurvivorRatio=8决定了新生代中Eden区与一个Survivor区的空间比例是8:1,从输出的结果看到,新生代总可用空间为9216KB(Eden区+1个Survivor区的总容量)。
分配allocation4对象的语句时会发生一次Minor GC,这次GC的结果是新生代8192K变为1014K,而总内存占用量则几乎没有减少(因为allocation1、allocation2、allocation3三个对象都是存活的,虚拟机几乎没有找到可回收的对象)。这次GC发生的原因是给allocation4分配内存的时候,发现Eden已经被占用了6MB,剩余空间已不足以分配allocation4所需的4MB内存,因此发生Minor GC。GC期间虚拟机又发现已有的3个2MB大小的对象全部无法放入Survivor空间(Survivor空间只有1MB大小),所以只好通过分配担保机制提前转移到老年代去。
这次GC结束后,4MB的allocation4对象顺利分配在Eden中,因此程序执行完的结果是Eden占用4MB(被allocation4占用),Survivor空闲,老年代被占用6MB(被allocation1、allocation2、allocation3占用)。
新生代GC(Minor GC):指发生在新生代的垃圾收集动作,因为Java对象大多都具备朝生夕灭的特性,所以Minor GC非常频繁,一般回收速度也比较快。
老年代GC(Major GC/Full GC):指发生在老年代的GC,出现了Major GC,经常会伴随至少一次的Minor GC(但非绝对的,在Parallel Scavenge收集器的收集策略里就有直接进行Major GC的策略选择过程)。Major GC的速度一般会比Minor GC慢10倍以上。
大对象直接进入老年代 虚拟机提供了一个-XX:PretenureSizeThreshold参数,令大于这个设置值的对象直接在老年代分配。这样做的目的是避免在Eden区及两个Survivor区之间发生大量的内存复制(复习一下:新生代采用复制算法收集内存)。
长期存活的对象将进入老年代 如果对象在Eden出生并经过第一次Minor GC后仍然存活,并且能被Survivor容纳的话,将被移动到Survivor空间中,并且对象年龄设为1。对象在Survivor区中每“熬过”一次Minor GC,年龄就增加1岁,当它的年龄增加到一定程度(默认为15岁),就将会被晋升到老年代中。对象晋升老年代的年龄阈值,可以通过参数-XX:MaxTenuringThreshold设置。
动态对象年龄判定 为了能更好地适应不同程序的内存状况,虚拟机并不是永远地要求对象的年龄必须达到了MaxTenuringThreshold才能晋升老年代,如果在Survivor空间中相同年龄所有对象大小的总和大于Survivor空间的一半,年龄大于或等于该年龄的对象就可以直接进入老年代,无须等到MaxTenuringThreshold中要求的年龄。
空间分配担保 在发生Minor GC之前,虚拟机会先检查老年代最大可用的连续空间是否大于新生代所有对象总空间,如果这个条件成立,那么Minor GC可以确保是安全的。如果不成立,则虚拟机会查看HandlePromotionFailure设置值是否允许担保失败。如果允许,那么会继续检查老年代最大可用的连续空间是否大于历次晋升到老年代对象的平均大小,如果大于,将尝试着进行一次Minor GC,尽管这次Minor GC是有风险的;如果小于,或者HandlePromotionFailure设置不允许冒险,那这时也要改为进行一次Full GC。
