当前位置:首页 > 芯闻号 > 充电吧
[导读]Database parameters and supported database interfacesThe following table lists each supported databa
The following table lists each supported database interface and the database parameters you can use with that interface in PowerBuilder. The database parameters are described in alphabetical order after the table.
ADO.NET
ADORelease
BindSPInput
CommandTimeout
CommitOnDisconnect
Database
DataLink
DataSource
DateFormat
DateTimeFormat
DBConfigSection
DecimalSeparator
DefaultProcOwner
DelimitIdentifier
DisableBind
GenerateEqualsNull
IdentifierQuoteChar
Isolation
Namespace
NCharBind (Oracle only)
OJSyntax
PBCatalogOwner
PBMaxBlobSize
Provider
ProviderString
RecheckRows
SPCache
StaticBind
TimeFormat
Timeout
TrimSpaces
TrustedConnection
ASE Sybase Adaptive Server® Enterprise
Release
The Release database parameter must be set to 15 or higher to use the ASE interface.
AppName
Async
BinTxtBlob
Block (DirectConnect and Adaptive Server Enterprise)
CharSet
CommitOnDisconnect
CursorType
CursorUpdate
DateTimeAllowed
DBGetTime
DBTextLimit
DelimitIdentifier
DisableBind
DS_Alias
DS_Copy
DS_DitBase
DS_Failover
DS_Password
DS_Principal
DS_Provider
DS_TimeLimit
FoDialog
FormatArgsAsExp
GenerateEqualsNull
Host
KeepAlive
Language
Locale
Log
MaxConnect
OJSyntax
PacketSize (ASE, DIR, SNC, SYC)
PBCatalogOwner
ProxyUserName
PWDialog
PWEncrypt
PWExpDialog
Release
Sec_Channel_Bind
Sec_Confidential
Sec_Cred_Timeout
Sec_Data_Integrity
Sec_Data_Origin
Sec_Delegation
Sec_Keytab_File
Sec_Mechanism
Sec_Mutual_Auth
Sec_Network_Auth
Sec_Replay_Detection
Sec_Seq_Detection
Sec_Server_Principal
Sec_Sess_Timeout
ShowTempTables
StaticBind
SvrFailover
SystemProcs
TableCriteria
TrimSpaces
UnicharBind
UTF8
DIR Sybase DirectConnect™
AppName
Async
CharSet
CommitOnDisconnect
CursorUpdate
DateTimeAllowed
DBGetTime
DBTextLimit
DecimalSeparator
DelimitIdentifier
FormatArgsAsExp
GenerateEqualsNull
HostReqOwner
Language
Locale
LowerCaseIdent
MaxConnect
PBCatalogOwner
Request
ShowWarnings
SQLQualifiers
StaticBind
SystemOwner
TableCriteria
TrimSpaces
TRS
UseProcSyntax
UTF8
IN9 Informix
Async
BinTxtBlob
CommitOnDisconnect
DateTimeAllowed
DBGetTime
DecimalSeparator
DelimitIdentifier
DisableBind
GenerateEqualsNull
INET_DBPATH
INET_PROTOCOL
INET_SERVICE
OJSyntax
Scroll
ThreadSafe
TrimSpaces
I10 Informix
Async
BinTxtBlob
Client_Locale
CommitOnDisconnect
DateTimeAllowed
DBGetTime
Db_Locale
DecimalSeparator
DelimitIdentifier
DisableBind
EncryptionPass
Hint
GenerateEqualsNull
INET_DBPATH
INET_PROTOCOL
INET_SERVICE
OJSyntax
OnlineIndex
PBCatalogOwner
Scroll
StmtCache
StrByCharset
ThreadSafe
TrimSpaces
JDBC
Async
CacheName
CommitOnDisconnect
Date
DateTime
DBGetTime
DelimitIdentifier
DisableBind
Driver
FormatArgsAsExp
GenerateEqualsNull
GetConnectionOption
IdentifierQuoteChar
LoginTimeOut
MapDateToDateTime
MsgTerse
NumericFormat
OJSyntax
PBCatalogOwner
Properties
ProxyUserName
ReleaseConnectionOption
StaticBind
TableCriteria
Time
TraceFile
TrimSpaces
URL
UseContextObject
ODBC
Using DBParms with ODBC
These database parameters are supported by the PowerBuilder ODBC interface only if both the ODBC driver you are using and the back-end DBMS support the feature
Async
Block (ODBC, OLE DB, Oracle, and SNC)
CacheName
CallEscape
CommitOnDisconnect
ConnectOption
ConnectString
CursorLib
CursorLock
CursorScroll
Date
DateTime
DBGetTime
DecimalSeparator
DefaultProcOwner
DelimitIdentifier
DelimitIdentifierToDB
DisableBind
FormatArgsAsExp
GenerateEqualsNull
GetConnectionOption
IdentifierQuoteChar
InsertBlock
LoginTimeOut
MsgTerse
NumericFormat
ODBCU_CONLIB
OJSyntax
PacketSize (ODBC)
PBCatalogOwner
PBNewSPInvocation
PBTrimCharColumns
PBUseProcOwner
ProxyUserName
RPCRebind
SQLCache
StaticBind
StripParmNames
TableCriteria
Time
TrimSpaces
UseContextObject
OLE DB
BinTxtBlob
CacheAuthentication
CommitOnDisconnect
DataLink
DataSource
DateFormat
DateTimeFormat
DecimalSeparator
DelimitIdentifier
DisableBind
EncryptPassword
GenerateEqualsNull
IdentifierQuoteChar
ImpersonationLevel
Init_Prompt
IntegratedSecurity
LCID
Location
MaskPassword
Mode
OJSyntax
PBCatalogOwner
PBMaxBlobSize
PBTrimCharColumns
PersistEncrypted
PersistSensitive
ProtectionLevel
Provider
ProviderString
RecheckRows
ReturnCommandHandle
ServiceComponents
SPCache
StaticBind
TimeFormat
Timeout
ORA Oracle 11g
O10 Oracle 10g
Oracle 9.2 or later databases
AppDriverName (ORA only)
Async
BindSPInput
BinTxtBlob
CacheName
CnnPool (deprecated)
CommitOnDisconnect
ConnectAs
CSIncr (ORA only)
CSMax (ORA only)
CSMin (ORA only)
Date
DateTime
DBGetTime
DecimalSeparator
DelimitIdentifier
DisableBind
FoDelay
FoDialog
FoRetryCount
FormatArgsAsExp
GenerateEqualsNull
GetConnectionOption
HANotification (O10 and later)
MaxFetchBuffer
MixedCase
NCharBind
NCharLiteral (O10 and later)
NLS_Charset
NumbersInternal
ObjectMode
OJSyntax
OraMTSConFlgs
PackageProcs
PBCatalogOwner
PBNoCatalog
PoolCreator (ORA only)
Pooling (ORA only)
PoolPwd (ORA only)
PWDialog
PWExpDialog
QualifyPublic
RTConnBalancing (ORA only)
SPCache
ServerName (ORA only)
SessionHomogeneous (ORA only)
StatementCache (O10 and later)
StaticBind
StrByCharset
SvrFailover
TableCriteria
ThreadSafe
Time
TimeStamp
TrimSpaces
UseContextObject
SNCSQL Native Client for Microsoft SQL Server
AppName
BindSPInput
BindSPInput
BinTxtBlob
CommitOnDisconnect
Database
DataLink
DateFormat
DBTextLimit
DecimalSeparator
DelimitIdentifier
DisableBind
Encrypt
FailoverPartner
GenerateEqualsNull
HighSeverityError
Host
Identity
NCharBind
OJSyntax
PBCatalogOwner
PBMaxBlobSize
PBMaxTextSize
Provider
ProviderString
RechecRows
SPCache
StaticBind
TimeFormat
Timeout
TrimSpaces
TrustedConnection
TrustServerCertificate
SYC Sybase Adaptive Server® Enterprise
Set Release
The Release database parameter must be set to the version of your Open Client® software (11 or higher) to use DS_* and Sec_* parameters.
AppName
Async
BinTxtBlob
CharSet
CommitOnDisconnect
CursorType
CursorUpdate
DateTimeAllowed
DBGetTime
DBTextLimit
DelimitIdentifier
DisableBind
DS_Alias
DS_Copy
DS_DitBase
DS_Failover
DS_Password
DS_Principal
DS_Provider
DS_TimeLimit
FoDialog
FormatArgsAsExp
GenerateEqualsNull
Host
KeepAlive
Language
Locale
Log
MaxConnect
OJSyntax
PBCatalogOwner
ProxyUserName
PWDialog
PWEncrypt
PWExpDialog
Release
Sec_Channel_Bind
Sec_Confidential
Sec_Cred_Timeout
Sec_Data_Integrity
Sec_Data_Origin
Sec_Delegation
Sec_Keytab_File
Sec_Mechanism
Sec_Mutual_Auth
Sec_Network_Auth
Sec_Seq_Detection
Sec_Sess_Timeout
ShowTempTables
StaticBind
SvrFailover
SystemProcs
TableCriteria
TrimSpaces
UnicharBind
UTF8
SYJ Sybase Adaptive Server Enterprise
CacheName
CursorUpdate
DBTextLimit
FormatArgsAsExp
GenerateEqualsNull
GetConnectionOption
Log
PBCatalogOwner
ProxyUserName
StaticBind
SvrFailover
SystemProcs
TrimSpaces
UseContextObject
UnicharBind
UTF8
Database interface
DBParm parameters
