当前位置:首页 > 芯闻号 > 充电吧
[导读]一、串口初始化定义: using System.IO.Ports; SerialPort myPort = new SerialPort() 初始化:
一、串口初始化
定义:
        //port初始化
        public void _port_Init(string comName)
            myPort.PortName = comName;
            myPort.BaudRate = 9600;
            myPort.DataBits = 8;
            myPort.Parity = Parity.None;
            myPort.ReadTimeout = 1000;
            myPort.Open();
            myPort.DataReceived += new SerialDataReceivedEventHandler(myPort_DataReceived);
二、串口接收事件
        //接收事件
        void myPort_DataReceived(object sender, SerialDataReceivedEventArgs e)
            if (myPort.IsOpen)
                try
                    byte[] receiveData = new byte[myPort.BytesToRead];//用receiveData数组读取                     myPort.Read(receiveData, 0, receiveData.Length);//读取数据
                    //myPort.DiscardInBuffer();                     for (int i = 0; i < receiveData.Length; i++)                     {                         check[i] = receiveData[i];                             //简单的定义了一个byte check[1000]接收数据                         Console.Write(check[i]);                     }
                    string strRcv = null;                     for (int i = 0; i < receiveData.Length; i++)                     {                         strRcv += receiveData[i].ToString("X2");//十六进制显示                     }                     /*使用委托,如果需要修改控件*/
                catch (System.Exception ex)
                    MessageBox.Show(ex.Message, "出错提示");
三、串口发送
对应单片机里的串口中断
            cmd = "55";
            bytCmd[0] = Convert.ToByte(cmd.Substring(0, 2), 16);
            myPort.Write(bytCmd, 0, 1);
存留备份
//port发送
        public void _port_DataSend(string strCommand)
            //处理数字转换
            string sendBuf = strCommand;
            string sendnoNull = sendBuf.Trim();
            string sendNOComma = sendnoNull.Replace(',', ' '); //去掉英文逗号
            string sendNOComma1 = sendNOComma.Replace(',', ' '); //去掉中文逗号
            string strSendNoComma2 = sendNOComma1.Replace("0x", ""); //去掉0x
            strSendNoComma2.Replace("0X", ""); //去掉0X
            //用' '分开成多个字符串,用strArray装
            string[] strArray = strSendNoComma2.Split(' ');
            int byteBufferLength = strArray.Length;//获取strArray个数
            for (int i = 0; i < strArray.Length; i++)//排除空格数字
                if (strArray[i] == "")
                    byteBufferLength--;
            // int temp = 0;
            byte[] byteBuffer = new byte[byteBufferLength];
            int ii = 0;
            for (int i = 0; i < strArray.Length; i++) //对获取的字符做相加运算
                int decNum = 0;
                decNum = Convert.ToInt32(strArray[i], 16); //atrArray[i] == 12时,temp == 18
                try //防止输错,使其只能输入一个字节的字符
                    byteBuffer[ii] = Convert.ToByte(decNum);
                    MessageBox.Show("字节越界,请逐个字节输入!", "Error");
                    //tmSend.Enabled = false;
                    return;
                ii++;
            myPort.Write(byteBuffer, 0, byteBuffer.Length);
四、一些参考目录:
http://blog.csdn.net/lllljz/article/details/7603400
http://www.cnblogs.com/elaron/archive/2011/03/15/1985378.html
http://blog.csdn.net/geekwangminli/article/details/7851673
http://blog.csdn.net/cy757/article/details/4474930
http://www.cnblogs.com/screes/p/5633383.html
               阅读(70) | 评论(0) | 转发(0) |                                                      0
上一篇:光衰代码整理学习
下一篇:STM32的结构和启动模式
相关热门文章            C# + Socket断线重连  C#解决EventHandler参数无法传...  解决因为sql server 存储过程...  水晶报表(使用VS2010配合水晶...  .Net/C# 开发WinFrom布局详解...
            给主人留下些什么吧!~~
         评论热议
