当前位置:首页 > 芯闻号 > 充电吧
[导读]首先看findOne的函数定义,该函数定义在BaseActiveRecord当中return static::findOne(['id' => $id, 'status' => self:
return static::findOne(['id' => $id, 'status' => self::STATUS_ACTIVE]);
findOne定义是:
public static function findOne($condition)
     return static::findByCondition($condition)->one();
也就是说我们需要看一下findByCondition的函数的定义,该函数定义在BaseActiveRecord
protected static function findByCondition($condition)
    $query = static::find();
    if (!ArrayHelper::isAssociative($condition)) {
     // query by primary key
       $primaryKey = static::primaryKey();
       if (isset($primaryKey[0])) {
          $condition = [$primaryKey[0] => $condition];
        } else {
          throw new InvalidConfigException('"' . get_called_class() . '" must have a primary key.');
    return $query->andWhere($condition);
find函数的定义是在ActiveRecord类中定义的
public static function find()
     return Yii::createObject(ActiveQuery::className(), [get_called_class()]);
也就是说$query是一个ActiveQuery的对象,其需要传入的参数是需要进行查询的类的名字"User"; 中间这一部分,先不要看,因为还没时间看,直接看下面的一行addWhere该函数的定义是在Query类中
public function andWhere($condition, $params = [])
    if ($this->where === null) {
       $this->where = $condition;
    } else {
       $this->where = ['and', $this->where, $condition];
    $this->addParams($params);
    return $this;
在这里仅仅是将传入的参数$condition,付给ActiveQuery的where成员变量。到此findByCondition已经执行完成,开始执行one函数。该函数定义在ActiveQuery类当中
public function one($db = null)
    $row = parent::one($db);
    if ($row !== false) {
        $models = $this->populate([$row]);
        return reset($models) ?: null;
    } else {
        return null;
首先调用父类Query的one函数,该函数定义如下:
    return $this->createCommand($db)->queryOne();
这里就需要看一下createCommand函数,该函数的定义是:
public function createCommand($db = null)
    if ($db === null) {
        $db = Yii::$app->getDb();
    list ($sql, $params) = $db->getQueryBuilder()->build($this);
    return $db->createCommand($sql, $params);
这里可以看到需要获得数据库链接配置,然后创建queryBuilder对象,并利用build模式构建完整的sql语句
public function build($query, $params = [])
   $query = $query->prepare($this);
   $params = empty($params) ? $query->params : array_merge($params, $query->params);
   $clauses = [
      $this->buildSelect($query->select, $params, $query->distinct, $query->selectOption),
      $this->buildFrom($query->from, $params),
      $this->buildJoin($query->join, $params),
      $this->buildWhere($query->where, $params),
      $this->buildGroupBy($query->groupBy),
      $this->buildHaving($query->having, $params),
    $sql = implode($this->separator, array_filter($clauses));
    $sql = $this->buildOrderByAndLimit($sql, $query->orderBy, $query->limit, $query->offset);
    if (!empty($query->orderBy)) {
        foreach ($query->orderBy as $expression) {
        if ($expression instanceof Expression) {
          $params = array_merge($params, $expression->params);
    if (!empty($query->groupBy)) {
      foreach ($query->groupBy as $expression) {
    $union = $this->buildUnion($query->union, $params);
    if ($union !== '') {
        $sql = "($sql){$this->separator}$union";
    return [$sql, $params];
好吧,看看这个吧!!! 这一部分使用了build模式,进行创建整个sql语句下面的几个函数就先不说了,因为这一部分就是分部分进行构建查询语句,分部分构建select  from join   where group having  每个函数都构建了一部分语句,最后各个部分语句形成了$clauses是由各部分语句的数组。最后返回$sql, $param的数组,得到$sql之后可以继续执行了,,接下来创建$command
public function createCommand($sql = null, $params = [])
    /** @var Command $command */
    $command = new $this->commandClass([
     'db' => $this,
      'sql' => $sql,
    return $command->bindValues($params);
bindValues函数如下:
public function bindValues($values)
    if (empty($values)) {
     return $this;
    $schema = $this->db->getSchema();
    foreach ($values as $name => $value) {
       if (is_array($value)) {
         $this->_pendingParams[$name] = $value;
         $this->params[$name] = $value[0];
       } else {
         $type = $schema->getPdoType($value);
         $this->_pendingParams[$name] = [$value, $type];
         $this->params[$name] = $value;
    return $this;
先认为param是空的吧,这一路跟下来,脑袋都快炸了,接下来要执行的是,yiidbcommand类的queryOne函数
public function queryOne($fetchMode = null)
    return $this->queryInternal('fetch', $fetchMode);
queryInternal函数定义
protected function queryInternal($method, $fetchMode = null)
    $rawSql = $this->getRawSql();
    Yii::info($rawSql, 'yiidbCommand::query');
    if ($method !== '') {
       $info = $this->db->getQueryCacheInfo($this->queryCacheDuration, $this->queryCacheDependency);
       if (is_array($info)) {
           /* @var $cache yiicachingCache */
          $cache = $info[0];
          $cacheKey = [
          __CLASS__,
          $method,
          $fetchMode,
          $this->db->dsn,
          $this->db->username,
          $rawSql,
          $result = $cache->get($cacheKey);
          if (is_array($result) && isset($result[0])) {
                Yii::trace('Query result served from cache', 'yiidbCommand::query');
                return $result[0];
    $this->prepare(true);
    $token = $rawSql;
   try {
       Yii::beginProfile($token, 'yiidbCommand::query');
       $this->pdoStatement->execute();
       if ($method === '') {
           $result = new DataReader($this);
        } else {
           if ($fetchMode === null) {
              $fetchMode = $this->fetchMode;
           $result = call_user_func_array([$this->pdoStatement, $method], (array) $fetchMode);
           $this->pdoStatement->closeCursor();
        Yii::endProfile($token, 'yiidbCommand::query');
    } catch (Exception $e) {
        throw $this->db->getSchema()->convertException($e, $rawSql);
    if (isset($cache, $cacheKey, $info)) {
        $cache->set($cacheKey, [$result], $info[1], $info[2]);
        Yii::trace('Saved query result in cache', 'yiidbCommand::query');
    return $result;
这样看来,就是讲所有的查询结果进行返回,那么会有人问不是findOne吗?在哪里进行的取one操作呢?是在ActiveQuery的one操作中,父类得到所有的查询结果,子类将查询结果进行reset操作,将第一行记录返回
查询总览: 所有的都是这样查询的static::findOne(条件),findOne函数定义是在BaseActiveRecord类中定义的,因为当前使用的User类的父类是ActiveRecord而ActiveRecord的父类是BaseActiveRecord 在此调用的是findByCondition在该函数中获得了ActiveQuery类的对象,同时传入需要修改的类的名称(需要调用该类的静态函数tableName,获得表名称),并且在findByCondition中将条件数组转成 String,方便继续使用,继续调用ActiveQuery的addWhere记录下ActiveQuery的where条件,之后调用Query的one()函数,在Query的one函数中创建了yiidbConnection类的对象,继续调用该db对象的getQueryBuilder函数,创建了一个QueryBuilder对象,然后在QUeryBuilder对象中进行完整的sql构造,将sql查询语句中可能出现的各个子查询都进行分别处理,各部分处理结果得到一个字符串,将这部分字符串组成数组,在展开implode,合成一个sql语句,将生成的sql语句传递给由yiidbConnection创建的yiidbcommand对象,并进行执行queryOne函数该函数调用queryInternal并返回结果集,最后由ActiveQuery的one函数进行reset操作,返回第一个结果记录
