当前位置:首页 > 芯闻号 > 充电吧
[导读]本文是在centOs 7 上安装sentry的全过程,亲测可行1. 关掉CentOs防火墙,允许服务器联网 1.1 su 更换root用户 1.2 sudo chmod 0777 /etc/sud
1. 关掉CentOs防火墙,允许服务器联网 1.1 su 更换root用户 1.2 sudo chmod 0777 /etc/sudoers 1.3 vi /etc/sudoers 1.4 在root ALL=(ALL) ALL下添加一行 john ALL=(ALL) ALL 1.5 sudo chmod 0440 /etc/sudoers 更换为原来的权限 1.6 关闭防火墙 sudo service firewalld stop
2. 编辑网卡驱动文件 2.1 vi /etc/sysconfig/network-scripts/ifcfg-ens33 将 ONBOOT设置为yes 2.2 重启网络服务 sudo service network restart 3. 安装wget 3.1 yum install wget
4. 安装ssh 4.1 yum install openssh-server
5. 安装 gcc 5.1 yum install gcc 6. CentOs换源 6.1 mv /etc/yum.repos.d/CentOS-Base.repo /etc/yum.repos.d/CentOS-Base.repo.backup 6.2 wget -O /etc/yum.repos.d/CentOS-Base.repo http://mirrors.aliyun.com/repo/Centos-7.repo 6.3 yum clean all 6.4 yum makecache
7. 更新tcl 8.5 7.1 wget http://downloads.sourceforge.net/tcl/tcl8.6.0-src.tar.gz 7.2 sudo tar xzvf tcl8.6.0-src.tar.gz -C /usr/local/ 7.3 cd /usr/local/tcl8.6.0/unix/ 7.4 sudo ./configure 7.5 sudo make 7.6 sudo make install 8. 安装redis 8.1 wget http://download.redis.io/releases/redis-2.8.0.tar.gz 8.2 tar zxvf redis-2.8.0.tar.gz 8.3 cd redis-2.8.0.tar.gz/src 8.4 make 8.5 make install 8.6 ./redis-server &
9. 安装deltarpm 9.1 yum provides '*/applydeltarpm' 9.2 yum install deltarpm 10. 安装rabbitMq 10.1 rpm -Uvh https://dl.fedoraproject.org/pub/epel/epel-release-latest-7.noarch.rpm 10.2 sudo rpm -Uvh http://packages.erlang-solutions.com/erlang-solutions-1.0-1.noarch.rpm 10.1 wget http://www.rabbitmq.com/releases/rabbitmq-server/v3.6.1/rabbitmq-server-3.6.1-1.noarch.rpm 10.2 rpm --import https://www.rabbitmq.com/rabbitmq-signing-key-public.asc 10.5 yum install rabbitmq-server-3.6.1-1.noarch.rpm 网速太慢 先跳过 11 安装postgresql 11.1 yum install -y postgresql-server; 11.2 service postgresql initdb 11.3 vi /var/lib/pgsql/data/pg_hba.conf 修改 local 的 peer为trust 11.4 service postgresql start; 启动psql 11.5 su postgres; 更换postgres 用户 11.6 psql -U postgres postgres 11.7 password 设置新密码 11.8 create database "sentry"; 新建数据库 11.9 q ; 退出 11.10 exit
12 安装python环境设置 12.1 yum install -y gcc bzip2-devel.x86_64 sqlite-devel.x86_64 readline-devel.x86_64 libxslt-devel libffi-devel redis python-devel postgresql-devel* 12.2 wget http://www.python.org/ftp/python/2.7.9/Python-2.7.9.tgz; 12.3 tar -zxf Python-2.7.9.tgz; 12.4 cd Python-2.7.9; 12.5 ./configure --prefix=/usr/local/python2.7.9; 12.6 make 12.7 make install 12.8 cd 12.9 wget https://pypi.python.org/packages/source/d/distribute/distribute-0.6.49.tar.gz --no-check-certificate; 12.10 tar zxvf distribute-0.6.49.tar.gz; 12.11 cd distribute-0.6.49 12.12 /usr/local/python2.7.9/bin/python setup.py install; 12.13 yum install python-setuptools 12.14 easy_install virtualenv 12.14 easy_install virtualenvwrapper 12.15 mkdir -p /data/server/python-envs 12.16 vi ~/.bashrc 后面添加内容 export WORKON_HOME=/data/server/python-envs export VIRTUALENVWRAPPER_PYTHON=/usr/local/python2.7.9/bin/python export VIRTUALENVWRAPPER_VIRTUALENV=/usr/bin/virtualenv source /usr/bin/virtualenvwrapper.sh
12.16 source ~/.bashrc 12.17 mkvirtualenv sentry; 12.18 yum install libjpeg-turbo-devel 12.19 yum install openssl-devel 12.20 workon sentry 13 pip换源 13.1 pip install -i https://pypi.tuna.tsinghua.edu.cn/simple gevent
14 安装sentry 14.1 pip install sentry 14.2 pip install sentry[postgres]; 14.3 pip install sentry[postgres] --upgrade; 14.4 pip install gevent; 14.5 pip install eventlet; 15 环境设置 15.1 mkdir -p /data/server/sentry/etc; 15.2 sentry init /data/server/sentry/etc; 15.3 useradd sentry -s /sbin/nologin; 15.4 chown -Rf sentry:sentry /data/server/sentry/etc; 15.5 vi /data/server/sentry/etc/sentry.conf.py 修改postgres的用户名和密码 修正 /data/server/python-envs/sentry/lib/python2.7/site-packages/sentry/runner/initializer.py 的403 后面3行注释掉
16 sentry启动 16.1 sentry --config=/data/server/sentry/etc/sentry.conf.py upgrade; 创建 sentry用户名密码 16.2 export C_FORCE_ROOT="true" 16.3 sentry --config=/data/server/sentry/etc/sentry.conf.py run worker 16.4 遇到错误 UnicodeError /data/server/python-envs/sentry/lib/python2.7/site-packages/sentry/db/postgres/helpers.py 引入代码 import sys reload(sys) sys.setdefaultencoding('utf-8') 16.5 sentry init 16.6 修改配置文件 /data/server/sentry/etc/sentry.conf.py 设置EMAIL(在最后添加) 设置postgres的数据库密码 EMAIL_HOST = 'smtp.qq.com' EMAIL_HOST_PASSWORD = 'x162728' EMAIL_HOST_USER = '674026565@qq.com' EMAIL_PORT = 25 EMAIL_USE_TLS = True 16.6 sentry start 17 sentry 添加用户 17.1 sentry --config=~/.sentry/sentry.conf.py createuser
部署成功之后的开启过程 1 切换到root用户 1.1 su 1.2 service postgresql start; 1.3 启动redis redis-server & 1.4 workon sentry 1.5 source /data/server/python-envs/sentry/bin/activate 1.6 export C_FORCE_ROOT="true" 1.7 sentry run worker //开启另外一个窗口 1.8 sentry start //正式启动完成 额,还有一个1.9 别忘了关闭防火墙 1.9 sudo service firewalld stop
