当前位置:首页 > 芯闻号 > 充电吧
[导读]win7中mysql5.7.7的配置部署 分类: mysql 2015-08-09 16:21 115人阅读 评论(0) 收藏 举报 mysql1.从mysql网站下载mysql-5.7.
1.从mysql网站下载mysql-5.7.7-rc-winx64.zip;
2.将mysql-5.7.7-rc-winx64.zip解压到相应的安装目录中(例如:D:dev_tools目录下);
3.将D:dev_toolsmysql-5.7.7文件加下的my-default.ini文件命名为my.ini;
4.修改my.ini文件(不修改也可以):
# For advice on how to change settings please see
# http://dev.mysql.com/doc/refman/5.7/en/server-configuration-defaults.html
# *** DO NOT EDIT THIS FILE. It's a template which will be copied to the
# *** default location during install, and will be replaced if you
# *** upgrade to a newer version of MySQL.
[client]
default-character-set=utf8
[mysqld]
# Remove leading # and set to the amount of RAM for the most important data
# cache in MySQL. Start at 70% of total RAM for dedicated server, else 10%.
# innodb_buffer_pool_size = 128M
# Remove leading # to turn on a very important data integrity option: logging
# changes to the binary log between backups.
# log_bin
# These are commonly set, remove the # and set as required.
basedir = "D:dev_toolsmysql-5.7.7"
datadir = "D:dev_toolsmysql-5.7.7data"
tmpdir = "D:dev_toolsmysql-5.7.7data"
socket = "D:dev_toolsmysql-5.7.7datamysql.sock"
port = 3306
log-error = "D:dev_toolsmysql-5.7.7datamysql_error.log"
# server_id = .....
max_connections = 100
table_open_cache = 256
query_cache_size = 1M
tmp_table_size = 32M
thread_cache_size = 8
innodb_data_home_dir = "D:dev_toolsmysql-5.7.7data"
innodb_flush_log_at_trx_commit = 1
innodb_log_buffer_size = 128M
innodb_log_file_size = 10M
innodb_thread_concurrency = 16
innodb-autoextend-increment = 1000
# Remove leading # to set options mainly useful for reporting servers.
# The server defaults are faster for transactions and fast SELECTs.
# Adjust sizes as needed, experiment to find the optimal values.
join_buffer_size = 128M
sort_buffer_size = 32M
read_rnd_buffer_size = 32M
max_allowed_packet = 32M
explicit_defaults_for_timestamp = true
sql_mode="STRICT_TRANS_TABLES,NO_AUTO_CREATE_USER,NO_ENGINE_SUBSTITUTION"
5.配置环境变量,即将“D:dev_toolsmysql-5.7.7bin”添加到path中(注意变量之间用“;”隔开);
6.添加服务:打开cmd命令模式,切换到目录“D:dev_toolsmysql-5.7.7bin”,执行mysqld -install mysql57(可配,默认为mysql);
7.启动服务:在cmd命令模式下,输入net start mysql57,数据库即可启动。
8.修改root密码:
命令行执行:mysql –u root -p
mysql>show databases;
mysql>use mysql;
mysql> SET password=PASSWORD('123456');
mysql> FLUSH PRIVILEGES;
mysql
