当前位置:首页 > 芯闻号 > 充电吧
[导读]在windows的通用开发平台上,有MFC或者STL的支持,很少自己去编写一个链表list程序。现在把Linux下的list.h取出来,在Windows平台上实现:我这里用的是Linux2.4版本的,
我这里用的是Linux2.4版本的,2.6版本的其实都一样,下面是修改后的list.h源文件,注意几点:① 注释掉了和Linux相关的字眼,如第四行、第六行等,添加了prefetch(w)两个函数的实现;② 因为是在C语言下实现(不是C++),VC6-VC2005-VC2010编译器均不支持C99,而这些编译器遵循的C89规范里不支持inline关键字,所以关键字inline要去掉,直接查找替换为无即可,这一点和gcc的编译器不同;③ C语言里,函数中所有的变量定义一定要放在函数的开始部分,一次性定义完毕,不要在函数体内再定义变量,这一点高版本的VS2010也是如此。
#ifndef _LINUX_LIST_H
#define _LINUX_LIST_H
//#if defined(__KERNEL__) || defined(_LVM_H_INCLUDE)
//#includevoid prefetch(const void *x) {;}
 void prefetchw(const void *x) {;}
 * Simple doubly linked list implementation.
 * Some of the internal functions ("__xxx") are useful when
 * manipulating whole lists rather than single entries, as
 * sometimes we already know the next/prev entries and we can
 * generate better code by using them directly rather than
 * using the generic single-entry routines.
struct list_head {
	struct list_head *next, *prev;
#define LIST_HEAD_INIT(name) { &(name), &(name) }
#define LIST_HEAD(name)
	struct list_head name = LIST_HEAD_INIT(name)
#define INIT_LIST_HEAD(ptr) do {
	(ptr)->next = (ptr); (ptr)->prev = (ptr);
} while (0)
 * Insert a new entry between two known consecutive entries.
 * This is only for internal list manipulation where we know
 * the prev/next entries already!
static  void __list_add(struct list_head *new,
			      struct list_head *prev,
			      struct list_head *next)
	next->prev = new;
	new->next = next;
	new->prev = prev;
	prev->next = new;
 * list_add - add a new entry
 * @new: new entry to be added
 * @head: list head to add it after
 * Insert a new entry after the specified head.
 * This is good for implementing stacks.
static  void list_add(struct list_head *new, struct list_head *head)
	__list_add(new, head, head->next);
 * list_add_tail - add a new entry
 * @head: list head to add it before
 * Insert a new entry before the specified head.
 * This is useful for implementing queues.
static  void list_add_tail(struct list_head *new, struct list_head *head)
	__list_add(new, head->prev, head);
 * Delete a list entry by making the prev/next entries
 * point to each other.
static  void __list_del(struct list_head *prev, struct list_head *next)
	next->prev = prev;
	prev->next = next;
 * list_del - deletes entry from list.
 * @entry: the element to delete from the list.
 * Note: list_empty on entry does not return true after this, the entry is in an undefined state.
static  void list_del(struct list_head *entry)
	__list_del(entry->prev, entry->next);
	entry->next = (void *) 0;
	entry->prev = (void *) 0;
 * list_del_init - deletes entry from list and reinitialize it.
static  void list_del_init(struct list_head *entry)
	INIT_LIST_HEAD(entry);
 * list_move - delete from one list and add as another's head
 * @list: the entry to move
 * @head: the head that will precede our entry
static  void list_move(struct list_head *list, struct list_head *head)
        __list_del(list->prev, list->next);
        list_add(list, head);
 * list_move_tail - delete from one list and add as another's tail
 * @head: the head that will follow our entry
static  void list_move_tail(struct list_head *list,
        list_add_tail(list, head);
 * list_empty - tests whether a list is empty
 * @head: the list to test.
static  int list_empty(struct list_head *head)
	return head->next == head;
static  void __list_splice(struct list_head *list,
	struct list_head *first = list->next;
	struct list_head *last = list->prev;
	struct list_head *at = head->next;
	first->prev = head;
	head->next = first;
	last->next = at;
	at->prev = last;
 * list_splice - join two lists
 * @list: the new list to add.
 * @head: the place to add it in the first list.
static  void list_splice(struct list_head *list, struct list_head *head)
	if (!list_empty(list))
		__list_splice(list, head);
 * list_splice_init - join two lists and reinitialise the emptied list.
 * The list at @list is reinitialised
static  void list_splice_init(struct list_head *list,
	if (!list_empty(list)) {
		INIT_LIST_HEAD(list);
 * list_entry - get the struct for this entry
 * @ptr:	the &struct list_head pointer.
 * @type:	the type of the struct this is embedded in.
 * @member:	the name of the list_struct within the struct.
#define list_entry(ptr, type, member)
	((type *)((char *)(ptr)-(unsigned long)(&((type *)0)->member)))
 * list_for_each	-	iterate over a list
 * @pos:	the &struct list_head to use as a loop counter.
 * @head:	the head for your list.
#define list_for_each(pos, head)
	for (pos = (head)->next, prefetch(pos->next); pos != (head);
        	pos = pos->next, prefetch(pos->next))
 * list_for_each_prev	-	iterate over a list backwards
#define list_for_each_prev(pos, head)
	for (pos = (head)->prev, prefetch(pos->prev); pos != (head);
        	pos = pos->prev, prefetch(pos->prev))
 * list_for_each_safe	-	iterate over a list safe against removal of list entry
 * @n:		another &struct list_head to use as temporary storage
#define list_for_each_safe(pos, n, head)
	for (pos = (head)->next, n = pos->next; pos != (head);
		pos = n, n = pos->next)
 * list_for_each_entry	-	iterate over list of given type
 * @pos:	the type * to use as a loop counter.
#define list_for_each_entry(pos, head, member)
	for (pos = list_entry((head)->next, typeof(*pos), member),
		     prefetch(pos->member.next);
	     &pos->member != (head);
	     pos = list_entry(pos->member.next, typeof(*pos), member),
		     prefetch(pos->member.next))
 * list_for_each_entry_safe - iterate over list of given type safe against removal of list entry
 * @n:		another type * to use as temporary storage
#define list_for_each_entry_safe(pos, n, head, member)
		n = list_entry(pos->member.next, typeof(*pos), member);
	     pos = n, n = list_entry(n->member.next, typeof(*n), member))
 * list_for_each_entry_continue -       iterate over list of given type
 *                      continuing after existing point
#define list_for_each_entry_continue(pos, head, member)
	for (pos = list_entry(pos->member.next, typeof(*pos), member),
//#endif /* __KERNEL__ || _LVM_H_INCLUDE */
#endif
下面是测试程序:
#include "stdio.h"
#include#include#include "list.h"
//自定义的数据结构
struct list_test_struct
	struct list_head	list;
	int key;
	int data;
void main()
	struct list_head list = {0};  //定义链表(头)
	struct list_head *pos = NULL;
	struct list_head *n = NULL;
	int i=0;
	printf("定义链表n");
	printf("初始化链表!rn");
	INIT_LIST_HEAD(&list);  //初始化链表(头尾相接,形成空链表循环)
	//判断链表是否为空
	printf("判断链表是否为空:");
	if(list_empty(&list)){
		printf("空rn");
	}else{
		printf("非空rn");
	//批量添加节点
	printf("批量添加节点:rn");
	for(i=0;ikey=key;
		st->data=data;
		list_add(&st->list, &list);
	//显示列表所有节点
	printf("显示列表所有节点:rn");
	list_for_each(pos,&list)
		struct list_test_struct *st=list_entry(pos,struct list_test_struct,list);
		printf( "t node:key(%d),data(%d)rn",st->key,st->data);
	//释放所有节点资源
	printf("释放所有节点资源!rn");
	list_for_each_safe(pos,n,&list)
		list_del(pos);  //删除节点,删除节点必须在删除节点内存之前
		free(st);   //释放节点内存
对于复杂的宏定义,可以使用人工宏展开方式来查看:【Setting】 ->【C/C++】在底部的输入选项中,添加“/P”再次编译可以得到一个扩展名为i的文件,既是宏展开后的文件
