当前位置:首页 > 芯闻号 > 充电吧
[导读]importjava.lang.reflect.Field;importjava.util.LinkedList;importjava.util.concurrent.ExecutorService;
importjava.util.concurrent.Executors;
importjava.util.concurrent.Semaphore;
importandroid.graphics.Bitmap;
importandroid.graphics.BitmapFactory;
importandroid.os.Handler;
importandroid.os.Looper;
importandroid.os.Message;
importandroid.support.v4.util.LruCache;
importandroid.util.DisplayMetrics;
importandroid.view.ViewGroup.LayoutParams;
importandroid.widget.ImageView;
publicclass ImageLoader {
     * 图片缓存的核心类
    privateLruCache
     * 线程池
    privateExecutorService mThreadPool;
     * 队列的调度方式
    privateType mType = Type.LIFO;
     * 任务队列
    privateLinkedList
     * 轮询的线程
    privateThread mPoolThread;
    privateHandler mPoolThreadHander;
     * 运行在UI线程的handler,用于给ImageView设置图片
    privateHandler mHandler;
     * 引入一个值为1的信号量,防止mPoolThreadHander未初始化完成
    privatevolatile Semaphore mSemaphore = newSemaphore(0);
     * 引入一个值为1的信号量,由于线程池内部也有一个阻塞线程,防止加入任务的速度过快,使LIFO效果不明显
    privatevolatile Semaphore mPoolSemaphore;
    privatestatic ImageLoader mInstance;
     * 队列的调度方式
     * @author zhy
    publicenum Type {
        FIFO, LIFO
     * 单例获得该实例对象
     * @return
    publicstatic ImageLoader getInstance() {
        if(mInstance == null) {
            synchronized(ImageLoader.class) {
                    mInstance = newImageLoader(1, Type.LIFO);
        returnmInstance;
    privateImageLoader(intthreadCount, Type type) {
        init(threadCount, type);
    privatevoid init(intthreadCount, Type type) {
        // loop thread
        mPoolThread = newThread() {
            @Override
            publicvoid run() {
                Looper.prepare();
                mPoolThreadHander = newHandler() {
                    @Override
                    publicvoid handleMessage(Message msg) {
                        mThreadPool.execute(getTask());
                        try{
                            mPoolSemaphore.acquire();
                        }catch(InterruptedException e) {
                // 释放一个信号量
                mSemaphore.release();
                Looper.loop();
        mPoolThread.start();
        // 获取应用程序最大可用内存
        intmaxMemory = (int) Runtime.getRuntime().maxMemory();
        intcacheSize = maxMemory / 8;
        mLruCache = newLruCache
            @Override
            protectedint sizeOf(String key, Bitmap value) {
                returnvalue.getRowBytes() * value.getHeight();
        mThreadPool = Executors.newFixedThreadPool(threadCount);
        mPoolSemaphore = newSemaphore(threadCount);
        mTasks = newLinkedList
        mType = type == null? Type.LIFO : type;
     * 加载图片
     * @param path
     * @param imageView
    publicvoid loadImage(finalString path, finalImageView imageView) {
        // set tag
        imageView.setTag(path);
        // UI线程
        if(mHandler == null) {
            mHandler = newHandler() {
                @Override
                    ImgBeanHolder holder = (ImgBeanHolder) msg.obj;
                    ImageView imageView = holder.imageView;
                    Bitmap bm = holder.bitmap;
                    String path = holder.path;
                    if(imageView.getTag().toString().equals(path)) {
                        imageView.setImageBitmap(bm);
        Bitmap bm = getBitmapFromLruCache(path);
        if(bm != null) {
            ImgBeanHolder holder = newImgBeanHolder();
            holder.bitmap = bm;
            holder.imageView = imageView;
            holder.path = path;
            Message message = Message.obtain();
            message.obj = holder;
            mHandler.sendMessage(message);
        }else{
            addTask(newRunnable() {
                @Override
                publicvoid run() {
                    ImageSize imageSize = getImageViewWidth(imageView);
                    intreqWidth = imageSize.width;
                    intreqHeight = imageSize.height;
                    Bitmap bm = decodeSampledBitmapFromResource(path, reqWidth,
                            reqHeight);
                    addBitmapToLruCache(path, bm);
                    holder.bitmap = getBitmapFromLruCache(path);
                    holder.path = path;
                    // Log.e("TAG", "mHandler.sendMessage(message);");
                    mPoolSemaphore.release();
     * 添加一个任务
     * @param runnable
    privatesynchronized void addTask(Runnable runnable) {
        try{
            // 请求信号量,防止mPoolThreadHander为null
            if(mPoolThreadHander == null)
                mSemaphore.acquire();
        mTasks.add(runnable);
        mPoolThreadHander.sendEmptyMessage(0x110);
     * 取出一个任务
     * @return
    privatesynchronized Runnable getTask() {
        if(mType == Type.FIFO) {
            returnmTasks.removeFirst();
        }elseif (mType == Type.LIFO) {
            returnmTasks.removeLast();
        returnnull;
     * 单例获得该实例对象
     * @return
    publicstatic ImageLoader getInstance(intthreadCount, Type type) {
                    mInstance = newImageLoader(threadCount, type);
        returnmInstance;
     * 根据ImageView获得适当的压缩的宽和高
     * @param imageView
     * @return
    privateImageSize getImageViewWidth(ImageView imageView) {
        ImageSize imageSize = newImageSize();
        finalDisplayMetrics displayMetrics = imageView.getContext()
                .getResources().getDisplayMetrics();
        finalLayoutParams params = imageView.getLayoutParams();
        intwidth = params.width == LayoutParams.WRAP_CONTENT ? 0: imageView
                .getWidth();// Get actual image width
        if(width <= 0)
            width = params.width; // Get layout width parameter
        if(width <= 0)
            width = getImageViewFieldValue(imageView, "mMaxWidth");// Check
        // maxWidth
        // parameter
        if(width <= 0)
            width = displayMetrics.widthPixels;
        intheight = params.height == LayoutParams.WRAP_CONTENT ? 0: imageView
                .getHeight();// Get actual image height
        if(height <= 0)
            height = params.height; // Get layout height parameter
        if(height <= 0)
            height = getImageViewFieldValue(imageView, "mMaxHeight");// Check
        // maxHeight
        // parameter
        if(height <= 0)
            height = displayMetrics.heightPixels;
        imageSize.width = width;
        imageSize.height = height;
        returnimageSize;
     * 从LruCache中获取一张图片,如果不存在就返回null。
    privateBitmap getBitmapFromLruCache(String key) {
        returnmLruCache.get(key);
     * 往LruCache中添加一张图片
     * @param key
     * @param bitmap
    privatevoid addBitmapToLruCache(String key, Bitmap bitmap) {
        if(getBitmapFromLruCache(key) == null) {
            if(bitmap != null)
                mLruCache.put(key, bitmap);
     * 计算inSampleSize,用于压缩图片
     * @param options
     * @param reqWidth
     * @param reqHeight
     * @return
    privateint calculateInSampleSize(BitmapFactory.Options options,
            intreqWidth, intreqHeight) {
        // 源图片的宽度
        intwidth = options.outWidth;
        intheight = options.outHeight;
        intinSampleSize = 1;
        if(width > reqWidth && height > reqHeight) {
            // 计算出实际宽度和目标宽度的比率
            intwidthRatio = Math.round((float) width / (float) reqWidth);
            intheightRatio = Math.round((float) width / (float) reqWidth);
            inSampleSize = Math.max(widthRatio, heightRatio);
        returninSampleSize;
     * 根据计算的inSampleSize,得到压缩后图片
     * @param pathName
     * @param reqWidth
     * @param reqHeight
     * @return
    privateBitmap decodeSampledBitmapFromResource(String pathName,
        // 第一次解析将inJustDecodeBounds设置为true,来获取图片大小
        finalBitmapFactory.Options options = newBitmapFactory.Options();
        options.inJustDecodeBounds = true;
        BitmapFactory.decodeFile(pathName, options);
        // 调用上面定义的方法计算inSampleSize值
        options.inSampleSize = calculateInSampleSize(options, reqWidth,
                reqHeight);
        // 使用获取到的inSampleSize值再次解析图片
        options.inJustDecodeBounds = false;
        Bitmap bitmap = BitmapFactory.decodeFile(pathName, options);
        returnbitmap;
    privateclass ImgBeanHolder {
        Bitmap bitmap;
        ImageView imageView;
        String path;
    privateclass ImageSize {
        intwidth;
        intheight;
     * 反射获得ImageView设置的最大宽度和高度
     * @param object
     * @param fieldName
     * @return
    privatestatic int getImageViewFieldValue(Object object, String fieldName) {
        intvalue = 0;
        try{
            Field field = ImageView.class.getDeclaredField(fieldName);
            field.setAccessible(true);
            intfieldValue = (Integer) field.get(object);
            if(fieldValue > 0&& fieldValue < Integer.MAX_VALUE) {
                value = fieldValue;
        }catch(Exception e) {
        returnvalue;
使用很简单,如果你在是Adapter中,
双击代码复制
ImageItem item = getItem(position);
        String path = item.getPath();
        ImageView imageView = holder.getImageView(R.id.img_plant);
        ImageLoader.getInstance().loadImage(path, imageView);
        imageView.setImageResource(R.drawable.pictures_no);
