当前位置:首页 > 芯闻号 > 充电吧
[导读];;有个题目,要求把 C 语言的程序,改成汇编的,链接如下:;;看他原来的程序,是驱动 8*8 LED 点阵显示字符的。;;根据程序,做而论道画出了点阵驱动电路,运行C程序后显示如下所示:;;;LED
;LED 所显示的全部字符都在下面给出了,有些字符的图形,还是很有创造力的,呵呵
;做而论道写出了功能相同的汇编程序,全部代码如下:
;8 * 8 LED 点阵
    ORG   0000H
    JMP   START
RED:
    DB  0x18,0x00,0x18,0x18,0x18,0x18,0x18,0x18;//i
    DB  0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0xFC,0xFC;//l
    DB  0x3C,0x42,0x42,0x42,0x42,0x42,0x42,0x3C;//o
    DB  0x00,0x00,0x44,0x44,0x44,0x44,0x28,0x10;//v
    DB  0x00,0x3E,0x02,0x02,0x3E,0x02,0x02,0x3E;//e
    DB  0x81,0xA5,0xDB,0xC3,0xA5,0x99,0x81,0xFF;//u
START:
    MOV   DPTR, #RED
    MOV   R2, #254
LP0:MOV   R3, #0
LP1:MOV   R5, #100
LP2:MOV   R4, #0
LP3:MOV   A, R3
    ADD   A, R4
    CALL  DISP
    INC   R4
    CJNE  R4, #8, LP3
    DJNZ  R5, LP2
    MOV   A, R3
    ADD   A, #8
    MOV   R3, A
    CJNE  R3, #48, LP1
    SJMP  LP0
DISP:
    MOVC  A, @A + DPTR
    MOV   P2, A
    MOV   P0, R2
    MOV   A, R2
    RL    A
    MOV   R2, A
    DJNZ  R7, $
    DJNZ  R7, $
    MOV   P2, #0
    RET
END
;做而论道把汇编程序提交后,却出现下面的提示:
;>_<!! 您的回答可能违反了知道内容规范,暂时仅您自己可见。可发起申诉找回。
;这种事情,出现过多次,申诉后,也没有什么结果的。
;呵呵,百度知道的某些网管,判断能力、水平,真难以用语言描述。
;本题目给出的 C 程序如下:
#include
#define uchar  unsigned char
#define uint   unsigned int
uchar code  RED[] = {
    0x18,0x00,0x18,0x18,0x18,0x18,0x18,0x18,//i
    0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0xFC,0xFC,//l
    0x3C,0x42,0x42,0x42,0x42,0x42,0x42,0x3C,//o
    0x00,0x00,0x44,0x44,0x44,0x44,0x28,0x10,//v
    0x00,0x3E,0x02,0x02,0x3E,0x02,0x02,0x3E,//e
    0x81,0xA5,0xDB,0xC3,0xA5,0x99,0x81,0xFF //u
void delay(uint t)
    for(; t > 0; t--);
void main()
    uchar r, j, q = 0, t = 0;
    while(1)  {
      for(r = 0; r < 40; r++) {
        for(j = q; j < q + 8; j++) {
          P0 = (~(0x01 << t));
          P2 = RED[j]; delay(200); P2 = 0;
          t++;  t %= 8;
      q += 8;  q %= 48;
大家可以试试,两种程序的功能,是否相同。
有位网友,利用反汇编 C 语言的方法,得出了汇编语言程序,程序长得多且不说,而且还编译不成功。
